Question on porting my TB
Old Jan 27, 2010 | 07:24 PM
69gto96z's Avatar
Default Question on porting my TB
I have been contemplating home porting a throttle body I have laying around to a 52mm. I figure it may help my motor breathe a little better with the cam. Only question I have is, if I port it, will I need to get larger blades to make up for the 4mm difference, of will the difference be too small so I won't have to worry about it?
Old Jan 27, 2010 | 07:45 PM
BlueRamAir's Avatar
You need to get the larger blades.
Old Jan 27, 2010 | 07:50 PM
69gto96z's Avatar
Thats what i figured. Where can you get them at?
Old Jan 27, 2010 | 08:01 PM
96lt1m6's Avatar
i have had 2 from here
http://cgi.ebay.com/ebaymotors/1993-...Q5fAccessories
Old Jan 27, 2010 | 09:00 PM
BlueRamAir's Avatar
I'm pretty sure thats where I gots mine.
Old Jan 27, 2010 | 10:05 PM
Badazz 97 TA's Avatar
If your doing it by hand I would be worried about not getting the holes perfectly round so the blades seal up correctly when closed .
Old Jan 27, 2010 | 11:11 PM
speed_demon24's Avatar
Originally Posted by 96lt1m6
I love his advertised gains
15-20 hp on a stock motor
50-100hp w/ cam and mild head work - i.e. valves & hand port
100hp+ on hot 383ci and larger motors
Old Jan 28, 2010 | 12:20 AM
69gto96z's Avatar
Ive got a mill and lathe to do it on. That would be a concern though if I was doing it by hand.
Old Jan 28, 2010 | 12:28 AM
69gto96z's Avatar
They wouldn't print it if it wasn't true!!
Old Jan 28, 2010 | 06:40 AM
96lt1m6's Avatar
I never pay attention to advertised HP gains before you know it you have a 700 HP motor that runs 13s
Old Jan 28, 2010 | 07:00 AM
97pontta's Avatar
If you have a lathe and a mill to do the throttle body just make the 52mm blades.
Old Jan 28, 2010 | 01:22 PM
69gto96z's Avatar
You are absolutely correct, why didn't I think of that.
