Speedinc 93 fuel line relocation... Pics inside
Hey Larry do you guys make a kit with everything for the 94-97 LT1s, if so how much is it and how far back do the braided lines go, all the way to the fuel tank?
EDIT, never mind I found it on the website, does it also include the fittings for the fuel rail?
Wow, that does look good. It's kind of funny, I just emailed Larry today asking about their kit for my '93.
A couple questions... How is the connection made on the bottom side? Also, do you think with a little more trimming the lines could be connected with maybe a 90deg at the manifold? What size are the hard lines underneath? It's been a while since I've been under my car (long story) but if I remember right they're about 1/4". The ones on the manifold look like they're 1/4" also. Any negative effects by stepping from 1/4" tubing to -6 (3/8") then back to 1/4"? I need to get out in the garage and take a look at mine and see. I'm in between doing this kit or just jumping in and modifying the rails for AN fittings and re-piping.
Edit: I just saw the post above mine about the bottom end connection.
That's it. Pretty easy right. The shredder valve was removed during the trimming of the hard line. So that it what the "T" fitting is for. It has a -4an to 1/8 to screw into the fitting and has a cap on there to retain pressure. This port is for a FPG or a nitrous fuel connection. In my case it will be both.
#33
I can go outside and take a picture or two for you right now. For warned though it is still dirty as hell on the bottom side due to my intake manifold and valve cover gasket blowing at the same time back before the tear down. It cant get cleaned off till I get it back on it own shoes lol.
#36
So do I. I am very satisfied. I am about 99.9% sure that almost anyone can do the needed work to the hardlines to make this kit work. It definitely cleans up the engine bay considerably. The only thing i have left to do is figure out a way to keep the lines close up against the wheel well. Without the plastic liner that comes factory there really isnt anything to hold the lines up. All in all though it turned out very well. Thanks again for putting everything together for this.
thanks for allowing me to put together this kit and sharing pics for everyone
There should have been 4 Adel clamps and self tapping screw to retain the lines. I can send some if they were not with the kit.
The 93 kit requires a little modification to the lines as you can see and the 94-97 kit does not.
please email or call me with any questions you might have
