Speedinc 93 fuel line relocation... Pics inside
#64
I'm still wondering why you cant just cut the hard line off where its straight underneath the rail. You wouldent have a valve, but still, it would look sooo much better. I lookes good this way too, but with the shorter stock valve covers, its gunna look taller and not so good
There's no reason you can't put a valve into the line back there.
#66
The rest for the way it was done was trial and error. The original intent was to attach up in the original 93 location. So the 180* was already purchased to accomplish this. After bending to try and lower the lines done some I realise it could not be accomplished in that fashion. So this is how it turned out. you xould cut it like the later models and just get the corrects fittings for a straight piece. Since the push lock style would not work on ours.
