plug wires.
Old Jan 28, 2010 | 06:05 PM
TravisMcGill2000's Avatar
Default plug wires.
I know this topic has been beat to death. What is the best plug wire for a heads, cam, and spray car. I ran summits 8.5 wires on my bolton car. Should i get a better wire.
Old Jan 28, 2010 | 06:08 PM
bigj2717's Avatar
I run taylor cut to fit 8mm i know most guys hate them but i havent had any problems with mine. The other opption is the MSD 8.5mm there are others out there but those are the 2 most people on here use
Old Jan 28, 2010 | 06:35 PM
RamAir95TA's Avatar
MSD 8.5mm seem to be the best nowadays. I ran Taylors for awhile and they were troublesome. Switched to MSDs and I'm quite happy.
Old Jan 28, 2010 | 07:17 PM
AChotrod's Avatar
No probs with my MSDs
Old Jan 28, 2010 | 08:21 PM
R3DLT1's Avatar
I went threw 2 set of MSD 8.5 before i decided to go with OTVC
Old Jan 28, 2010 | 10:18 PM
robsquikz28's Avatar
Msd for sure.
Old Jan 28, 2010 | 10:28 PM
AChotrod's Avatar
I would say thets your fault
Old Jan 28, 2010 | 10:36 PM
1badzee's Avatar
Originally Posted by AChotrod
I would say that's your fault
Agreed. If you route them correctly, you won't have any issues (e.i: routing the # 5 and 7 wire against the body by the ABS block on the driver side, avoiding the headers all together).
Old Jan 28, 2010 | 10:48 PM
MattSapp95_T/A's Avatar
Yea this is the best way to route them that I found too....
I am running taylor wires they have been good so far (knock on wood)
Old Jan 28, 2010 | 11:18 PM
BOLO's Avatar
If they are in good condition, why change 'em? Summit brand are good quality. But then again, MSD, Taylor, Moroso and other big name brands are proven performers.
Old Jan 29, 2010 | 08:02 AM
Elliott's94Z's Avatar
MSD here as well. Great wires. 99BlancoSS on here is a good contact for getting the MSD for a good price.
Old Jan 29, 2010 | 08:16 AM
06blackGTO's Avatar
I run taylor full metal jackets in my ta. Yeah there alittle high, but I like the better protection against the heat from the headers.
Old Jan 29, 2010 | 08:25 AM
99blancoSS's Avatar
http://estore.websitepros.com/212053...+%2B+OTVC+Kits
Taylor wires are horrible!
Old Jan 29, 2010 | 08:34 AM
95mysticta's Avatar
Like everyone says if you route them properly and also using zip ties you shouldnt have any issues. I burnt my first set cuz i didnt have them zip tied off to the head. On my second lt1 and header swap im using magnecore 8.5 and they work great and using the stock metal boot shields will help angle the wires off the 5 and 6 primarys. Dont think ill have any issues with them. Seems to feel alot better with a fresh tune up.
Old Jan 29, 2010 | 10:01 AM
pillarpod's Avatar
i love my MSDs
Old Jan 30, 2010 | 09:06 AM
camar0corey's Avatar
I don't understand wire burning issues? I have one boot on each side really close to my Pacesetters, all I do is have a heat sheath on these two I picked up at Autozone. I zip tie the wires to things close to the block, none of my wires are close to burning. If you spend over $80 for wires why are there still people not taking the time to make sure they can't touch the headers?
I'm getting a set of MSDs soon, I can't wait.
Old Jan 30, 2010 | 11:03 AM
You will understand why as soon as you get your MSD's. If you have headers you will really have to route and zip tie them out of the way. I burnt up two sets of MSD wires because they had either come loose or one was touching in a spot that was hard to see.
