Oil Pressure Question
Also I found out why im smelling oil burning... under pressure my tranny dipstick pops up a bit so im guessing the fluid comes out and spits up on the valve cover causing it to smell... if someone can help me out on what to do it would be fantastic
If anything, the standard tough guard fram is less restictive than many filters(one good example of a restrictive filter would be purolator pure one).. This filter has dense media and as such is more restrictive to oil flow. Still a very good filter.
The filter being plugged could cause this, but again not likely. Change the filter and see if there is a difference. Go with a regular wix or purolator if you want a less restrictive filter to compare against the Fram.
You don't have to drain all the oil just to change the filter. Fill the new filter with oil before putting it on (you should always do this, anyway) and you won't have to add hardly any oil to bring it back up to full.
