What kind of HP Should this be making ?
.030 over 2 bolt main block
Eagle forged Crank
Scat forged 5.7 Rods
Ross dished forged pistons
Comp 224/230 cam
Trick flow 195cc heads revalved with manley valves
Ported lt1 intake
37lb/hr injectors
Holley 58mm TB
Stock water pump
New opti
Going thru a built 4l60e with 3500 stall and a 9 inch
Any ways it put down 325hp/343tq at RPM
What is holding the power back on this car, Some seem to think its the knock module. its not mine but looking to get this car so some help would be greatly appreciated
Thanks to anyone with info
Eagle forged Crank
Comp 224/230 cam
Ported lt1 intake
37lb/hr injectors
Holley 58mm TB
Stock water pump
New opti
Should be makin more than that. What kind of stall is it. If you were runnin a TH400 I would say that would be low. My good friend made 420 rwhp through 6 speed then he put a TH400 in the car and it put down 385 rwhp.
With your mods you should be around 400 through the auto and 9 inch,
I would look into your converter. By the way **** a dyno take it to the track and look at your mph and weight of the car.
This past I summer I went to the track and ran consistent late 11's all day. I then put the car on a local dynojet for ***** and giggles and it put down only 350rwhp. I wouldn't get caught up on numbers. Keep in mind if the pulls were made with the stall unlocked then that right there is going to put out lower numbers. Also remember that 9 inch isn't helping any either. If the car is optimized meaning the compression is where it should be and the car is dyno tuned then take it to the track and see how it does and chances are it will move out good.
You need to datalog it first to see if its pulling timing.
Was this on a Mustang dyno or Dynojet?
What size cc is the piston? alot of those pistons are dished from -5 to -20cc's need to know the piston size.
Your dynamic is what realy matters though and it is usually lower than the static if I remember right.
First thing to check would be the rockers and pushrod size to make sure the things are sized and setup right other wise they could be holding the valves open. Pull one and check the valve stem wear. Should be centered.
To be honest it really sounds like it needs a blower to maximize the build that was done. I'd bet that thing would put down about 500+ at the wheels running a blower setup on it.
