le2 vs trickflow
Old Feb 1, 2010 | 05:17 PM
Wicked94Z's Avatar
Originally Posted by RamAir95TA
You should also consider www.advancedinduction.com. Your best bet is to contact both vendors and talk to them about your goals and they'll be able to help you out, no questions asked. You have a healthy budget for valvetrain so you're definitely on the right track.
I'd hope they are asking questions
In all seriousness, I'd spend the money on ported stock castings if you're on a tighter budget looking to get results.
Old Feb 1, 2010 | 07:15 PM
6801's Avatar
ai hasant got back to me yet website says 1395 for heads and 250 for cam 190 package
le ifelt confortable talking to
i talked to summit and trick flow they said the 185x flow 273 and 207 at 600 if thats true thats a bad *** head with a 185 port ther on backorder
intake is done just picked up ported intake 58 mm tb and 100-200 nitrous kit for 600$ now just have to pick the heads hows the comp cams 292xfi cam
Old Feb 1, 2010 | 07:19 PM
AChotrod's Avatar
Lloyd is awesome to work with and the service doesnt stop after you place an order.
Old Feb 1, 2010 | 07:22 PM
6801's Avatar
trick flow 185x heads they said flow 273 and 207 at 600 right out of the box i called them 3 times just to make sure i heard it right
Old Feb 1, 2010 | 08:01 PM
knight17Z's Avatar
I'd call LE or AI for the cam. also noone has said anything about TEA heads.
Old Feb 1, 2010 | 08:13 PM
kgkern01's Avatar
Flow#'s for the 21* TFS heads out-of-the-box from TrickFlow: https://ls1tech.com/forums/10495801-post26.html
These heads have CNC'd chambers and port entry. LE/AI would probably give you a few extra hp all else being equal, but you would already have some aftermarket castings that will flow 300+ cfm after porting out. Plus, both LE and AI are proven whereas no one has tried the 21* TFS yet? So it depends on your goals and willingness to tryout the untested 21* heads.
Old Feb 1, 2010 | 08:27 PM
kline454's Avatar
I would go with Lloyd, great customer service,
Old Feb 1, 2010 | 08:37 PM
6801's Avatar
i cant belive they flow like that out of the boxwith a cam near 600 lthey should make 500 hp with suporting mods if im able to find a pair im gonna go for it plus i can send them out next year when im building a 396 if i cant ill proably go le2 im sorry i found out about trickflow and really hope there that good
the one thing i learned in my life is edelbrock makes good stuff they just dont go fastthats just my opion
plus ant 21deg better
Old Feb 1, 2010 | 10:30 PM
pyro719's Avatar
Ive been watching these heads For about a year now and no one on this site is using them yet. If they really do flow that well and They should make 500 fwhp
Old Feb 1, 2010 | 11:10 PM
za355tx's Avatar
Generally people shy away from aftermarket casting heads unless they're put on stroker motors. While I've always gone with Lloyd, AI does some impressive work as well. If it were me I would either go with the AI 190cc heads or Lloyd's LE2 heads. Either way with a matched cam your car will run like a raped ape. It's actually pretty easy and reasonble to get a car into the 11's. There was a post not too long ago that a guy had a set of LE1 heads with a fairly small cam and made almost 400 rwhp. Lloyd actually told me once that unless you've got the money and are trying to squeeze out every last little hp you can...the LE2's are a very good choice as opposed to his LE3's. That's why so many people run them because there's only like 10hp difference. Just bigger valves and a tid bit more porting. Nothing major. But again I would stay away from the TFS heads with your setup and stick to having your stock heads ported by Lloyd or AI. You will be happy either way. Oh and as far as compression goes...my old LE2 heads had 50cc chambers, made for some wicked compression and ran great...until I parted the car due to low funds
Old Feb 1, 2010 | 11:27 PM
AChotrod's Avatar
Im still pissed about that^^^ Wanted to see the car run!
Old Feb 2, 2010 | 12:44 AM
  #32
marc97taws6's Avatar
If you have an LS1 air lid, 1 7/8 headers 3" true duals, etc. you might see a 5hp gain. Maybe 10 if you do a crazy intake manifold setup.
If you have a CAI, 1-3/4 headers and cat back exhaust, you will probably not see any gain at all going with LE3 heads
LE is very good at his very affordable LE2 heads with the LE3 being for crazy cubes and intake setups like I stated above
Old Feb 2, 2010 | 12:58 AM
  #33
Wicked94Z's Avatar
and this would be from your personal experience?
too much speculation in this thread. I've run both a ported stock casting and a ported aftermarket casting in both a stock shortblock and my current 388 combo. Ramair95 has experience with AI heads, achotrod has experience with LE heads. These are the people you need to be listening to.
Old Feb 2, 2010 | 01:10 AM
  #34
My above quote was from LE himself...
Old Feb 2, 2010 | 10:46 AM
  #35
RamAir95TA's Avatar
I think you knew what I meant. Perhaps I should have said "no unanswered questions."
Old Feb 2, 2010 | 11:11 AM
  #36
slomarao's Avatar
stay with stock casings on your budget. They will be the best bang for the buck. Sure the trickflows will be nice but if you cant afford them you cant afford them.
LE/AI all day
Old Feb 2, 2010 | 11:27 AM
  #37
96blkform's Avatar
If you are right by Akron, you could always look at TEA (Total Engine Airflow)
Old Feb 2, 2010 | 04:01 PM
  #38
6801's Avatar
i think im gonna go tf if i can find a set
Old Feb 2, 2010 | 04:35 PM
  #39
AChotrod's Avatar
Those should be nice heads, with lots of potential down the road! Then LE or AI or TEA can port them for you!!
