$600 sound right for custom true duals?
Hell my exhaust was a grand, but I don't have true duals either. I will just say that you don't want to cheap out on exhaust. If the shop is reputable and known to do a good job then $600 is better than multiple headaches in the future due to leaks and such.
• 2.5 inch stainless steel true duals with x-pipe or h-pipe, and Magnaflow mufflers:$1400
• 2.5 inch aluminized steel true duals with x-pipe or h-pipe, and Magnaflow mufflers:$1200
• 2.5 inch stainless steel true duals with x-pipe or h-pipe and Magnaflow mufflers (exit before axle) :$800
• 2.5 inch aluminized steel true duals with x-pipe or h-pipe and Magnaflow mufflers (exit before axle) :$600
• 3 inch stainless steel true duals with x-pipe or h-pipe and Dynomax mufflers (exit before axle) :$875
• 3 inch aluminized steel true duals with x-pipe or h-pipe and Dynomax mufflers (exit before axle) :$650
This is what we charge to do duals...
i will have to call them tomorrow and ask but im kind of guessing its probably crush. they have a website http://iowamufflersandbrake.weebly.com/ and it shows pictures of other systems they made for cars. im really dont know much about exhaust but it looks to me like they did some crush and some welding mandrel. i live in des moines iowa so i dont have a ton of options hah some shops tell me "cant run them true duals in them camaros wont fit with that driveshaft brace and it'd just rattle on everything" but they are the same people that said "cant fit long tube headers on those camaros you'd just drag em on the ground"
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Jesus!!! I guess ive been screwing myself then!!! At my shop ive been charging $280 with one chambers 2 1/2 over axle with h=pipe! thats with crush bend though, Mandrel machines are a ton of money $56k for the smallest an couldnt suit me well anough, When I need a straight flow no crush bends I just order my bends through my supplier
well i cant get pulled over so thats the main reason i ruled out dumping it..
is it way loud (cop pull over loud) when its dumped or does that just depend on what muffler you run?
