So i Finally bought an 8.8!
#41
i believe that you have to get custom made axles due to the fact that the 10 bolt tubes are longer than the 8.8s so i assume you can get them to make the rings with however many teeth you want
#42
Also...If I want to keep functional ABS (3 channel) what do I look for and what do I need to do to get this to work?? I saw pics of a ranger rear with a reluctor on the differential....and also read about Mustang rears with ABS reluctors on the axles. I'd assume the ranger set-up would work for 3 channel and the Mustang for 4 channel?? Know how assuming goes.
On another note, this week ill be putting in some serious OT working on this rear end. i have to set up the 10 bolt tubes on the lathe and see how true shell run. i threw it up there the other day and it looks to be off... im wondering what kind of tolerances need to be kept between the diff to the end bearing. Im an apprentice machinist so .005 of an inch is alot for me as far as tolerance goes. from what i saw it was around .125" ill figure it out and crunch the numbers this week. i want the housing done so i can finally beat the ever loving hell out of the car!
#43
I think he was talking about a 3 channel set up with the ring on the diff itself... but you are right. i have to call up moser and get custom axles made up for this setup. i dont want to order them until the housings complete tho so i know the exact length
#53
Sorry for the holdup...
Ive been extremely busy. Im sorry for holding up this thread and everyones expectations of my build. Without further adue. my recent progress...
mockup
Inner 8.8 axle tube has a seem. afew minutes with a grinder and no more seem.
Trueing up the 10 bolt tubes to slip fit into the 8.8 tubes.
all slipped together
Im going to send out my 10 bolt tubes and get them sandblasted. after that im going to angle everything and weld it together. Im waiting on my torque arm to arrive before i start making a bracket for that. Ill be keeping this updated whenever i make progress on this
mockup
#59
hahahaha! thats a crane that we made. ill take a picture of that next time if i remember.
nope. i didnt want to bother with sleeves. plus itll be stronger just putting the 10 bolt tubes directly inside the 8.8 tubes. im going to have it in there about 3" or so.
#60
I think by installing the 10bolt tubes into the 8.8 tubes will be a lot stronger in that area mine are 5+ inches in.
If it was not for the fact that i cannot stand ford brakes i would have left the ford axle tubes alone since they are 3.25''(EXPLORER) but small sacrifice i love my Ls1 brakes
