Headlight Mod
Old Feb 23, 2010 | 11:38 PM
94maro's Avatar
Default Headlight Mod
ok so ive seen on here someone has done a headlight mod were they can chenge the bulbs without having to change the whole assemebly??..got any pics of them or any info will help thanks.. p.s i need to do it because i keep blowing out my right head light some how...
Old Feb 24, 2010 | 12:22 AM
nomoneyz's Avatar
First I suggest that you figure out why you keep burning through headlights. Second there are a couple ways depending on what you want. If you want HID's then there is a kit and you can either buy new lenses or use your factory ones. Basically you take the whole headlight assembly and carefully with a set of pliers twist back and forth the bulb socket on the rear of the headlamp. The only crappy thing about this method is having to silicone or glue it back on. I don't remember who sells the new headlamp assembly where you can change bulbs. Maybe google? Or someone here might know. Don't know if I helped or not but I tried.
I personally did the HID's and I love them and have zero complaints. But since you keep burning headlight up, you might just burn up the HID bulbs also.
Old Feb 24, 2010 | 12:38 AM
litch2004's Avatar
http://www.speedinc.com/catagory.cfm?catagory=Lighting
There you go
Old Feb 24, 2010 | 01:02 AM
importben's Avatar
Here ya go.. I bought these myself.. put some HID's on em. came out great.
http://eurolamps.com/eurolamps/camaro_headlights.htm
Old Feb 24, 2010 | 10:08 AM
pillarpod's Avatar
https://ls1tech.com/forums/lt1-lt4-m...-question.html
Old Feb 24, 2010 | 03:41 PM
itSSlowZ28's Avatar
i have the silverstar bulbs in my stock housings and they are MUCH better than stock, but i still don't think the $80 is worth them. i'll be going to speed inc.'s HID kit next time around
Old Feb 24, 2010 | 04:15 PM
Johnny-LT1-runner's Avatar
Rockstar
You people are all overcomplicating this. This is the easiest thing you could do to these cars.
The same bulbs that fit LS1 Camaros will slip in just fine and can be RTV'd in.
Just take a blowtorch to get the old bulb out and its all cherry.
see?
Old and new side by side.
Old Feb 24, 2010 | 04:18 PM
SoxXpupPeT's Avatar
Originally Posted by litch2004
i have these. good buy. my lens were all shot. pacakge just plugs right in.
Old Feb 25, 2010 | 01:06 AM
94maro's Avatar
thanks everyone for your help i will be doing this sdoon..o and are the high beems a sertain kind or same bulbs jsut more power to them??
Old Feb 25, 2010 | 06:08 PM
Rockstar
The thing that makes them high beams is the fact that they don't have ceramic coating on the tip that blocks the direct light.
