Simple Vacume Line Question
Old Feb 24, 2010 | 08:24 PM
97ramsst's Avatar
Default Simple Vacume Line Question
I have a question for you...while changing the water pump on our white LT1 WS6 I found a vacume line that was loose that I have no idea where goes. Its wrapped up in the wiring harness and comes out right by the MAF sensor plug. Would you mind looking at your car real quick and seeing where it goes? The only place I could find it might go is into the bellows right in front of the throttle body but it won't fit into the hole there because of a airfoil inside of the bellows (I am not sure if its factory or not.) If you would take a min to look and let me know I would appreciate it!
Old Feb 24, 2010 | 08:33 PM
RamAir95TA's Avatar
Sounds like the vacuum line for the optispark. One end goes to the intake elbow and the other to the opti.
94Aquaformula's Avatar
if you would take a pic i could help you
Old Feb 24, 2010 | 09:38 PM
97ramsst's Avatar
OK this is the vacume line in question....it was just laying under the MAF when I found it. Its obviously been off for a while.
I would think it would go into that hole in the intake tube just to the right of it in the picture but it wont because there is a plastic airfoil inside of the bellows that blocks the hole. So first off should it go into that hole...if so is the airfoil aftermarket and in the way or is it just in the intake tube wrong?
Old Feb 24, 2010 | 10:16 PM
shbox's Avatar
Yep, it looks like it should go in that hole. It is the filtered air for the opti. No air foil is stock.
Old Feb 24, 2010 | 10:55 PM
97ramsst's Avatar
I didnt think it was stock but my wife has owned the car since it was almost brand new (she bought it when it was a year old and had 6000 miles) and I know she didnt add it...I guess the first owner put it in there. I guess if its been unfiltered for almost 14 years its nothing to panic about now.
At least the water pumps not leaking anymore!
Old Feb 24, 2010 | 11:58 PM
shbox's Avatar
The small amount of air drawn in goes right into the engine. At least plug the hole in the bellows and put a filter where the blue vacuum elbow is. (this is assuming the end at the intake is still hooked up)
Old Feb 25, 2010 | 12:32 AM
Coltf1991's Avatar
on my z28 its plugged in right on top of the factory elbow.
Old Feb 25, 2010 | 02:28 AM
97ramsst's Avatar
The hole in the bellows is plugged by that airfoil. I cant feel any air being sucked by the line at all.
Old Feb 25, 2010 | 06:45 AM
shbox's Avatar
You may not understand. That it is not a vacuum source. It is the filtered air supply to the opti. Vacuum comes from the other end.
http://shbox.com/ci/opti_vent.jpg
