Keep stock oil pan...?
How much oil do turbos need? Is this a meaningful factor in selecting an oil pump??
Not saying I have the answer, just saw a variable not usually discussed. I have never laid a hand on a turbo so I really do not know.
I can say I have a HV with a stock pan and have not experienced the pan being sucked dry....at least according to oil pressure gauge under and driving conditions I have been in.
). A deeper pan for more oil (and heat dissipation) might be a good idea, but I think an SV pump would be fine, too. Just the serious drive gear wear I have seen would make me scared enough of the HV pump. Kind of a judgement call on this one.Trending Topics
I think every aftermarket pan has problems, pick which ones you want to work though.
There is a Stef's for the b-body and my understanding is it needs thicker endseals and LOTS of "right stuff" to seal.
Stef's and Canton have been known to need a little silicon on a weld or two as well.
