My build thread! PICS!
Cory like I said the Freightliner truck shop has those in stock. They're called Stat-O-Seal washers..
By the way, where is the best place to wire the CSR Electric WP?? I have 2 wires, power and ground. I know it needs to come on then I turn the ignition on but it has to be a good spot that wont get hurt if the WP draws amps from it...any suggestions? Also what size fise do they use for theit fusable link?
I had an install guide with pictures but can't find it. If you troll enough threads you can find it on here.
The washers for the steam tube are available at advance auto (where I picked mine up) or autozone.
http://www.akmcables.com/2ledmez.jpg
http://www.teamandersonracing.com/Pr...28Optional%29:
Do a search theres plenty of info on how to wire the ewp up.
