355 No Power, Shakes.
Old Mar 3, 2010 | 02:33 PM
sepno77's Avatar
Default 355 No Power, Shakes.
I'm posting this for my brother. He has a 1995 M6 355 w/ 503 cam.
Problem: Car is down on HP and engine shakes in 5th and 6th gear.
New parts:
Opti
Wires
Plugs
ICM
Anyone have any ideas or suggestions?
Old Mar 3, 2010 | 02:39 PM
RamAir95TA's Avatar
Any codes? Could be a ton of things really. Start by checking fuel pressure.
Old Mar 3, 2010 | 02:49 PM
sepno77's Avatar
Thats what's making it so hard to fix. Code tester isn't connecting to the PCM. Will check the fuel pressure once we get a fuel pressure tester handy.
Old Mar 3, 2010 | 03:13 PM
AChotrod's Avatar
All the wires in the correct firing order? Made sure they didnt get burned?
Old Mar 3, 2010 | 03:58 PM
sepno77's Avatar
Wires are brand new and in the correct order.
Old Mar 3, 2010 | 04:14 PM
djjab57's Avatar
I would check again to make sure one didnt get burnt, Ive done it but you dont think thats it cause there new
Old Mar 3, 2010 | 04:15 PM
djjab57's Avatar
Happen 3 times to me LOL 2nd one on passenger side
Old Mar 3, 2010 | 04:18 PM
sepno77's Avatar
Wires were done today they are fine. Plugs were done last weekend.
Old Mar 3, 2010 | 07:42 PM
jaycenk's Avatar
is it only in 5th or 6th gear?
Old Mar 3, 2010 | 08:44 PM
sepno77's Avatar
well its the most noticable at low speeds. 40-50mph. His car should be pushing at least close to what I am and its no where near at the momoent w/ this bug.
Old Mar 4, 2010 | 11:11 AM
sepno77's Avatar
FOUND THE PROBLEM!
Cylinder # 8 spark plug was covered in oil.
What could cause this?
Piston Rings?
Valve seals?
His car has a new felpro intake mani gasket.
Old Mar 4, 2010 | 11:13 AM
RamAir95TA's Avatar
Uh, what was the problem?
Old Mar 4, 2010 | 11:28 AM
sepno77's Avatar
Old Mar 4, 2010 | 11:40 AM
RamAir95TA's Avatar
An oil-coated spark plug could be a couple things, like valve seals, guides, rings, etc., but if it's only the one plug (assuming the other 7 are fine), it's probably a poorly installed intake manifold gasket.
Old Mar 4, 2010 | 11:47 AM
sepno77's Avatar
Well I'm not 100% sure but I think it dose it on other cylinders just not as bad.
Old Mar 4, 2010 | 11:58 AM
RamAir95TA's Avatar
Did he pull any other plugs!?
Old Mar 4, 2010 | 02:10 PM
sepno77's Avatar
He said the rest are fine. He ran a compression test and that checks out fine as well.
Old Mar 4, 2010 | 02:37 PM
Next level's Avatar
check them all when your in there to save yourself time in the long run. I personally do not like doin things twice either way glad you found the fix.
Old Mar 4, 2010 | 06:48 PM
sepno77's Avatar
Well turns out once he put a new plug in it, It started runing strong from what I was just told.
