Motor Mount Issues... The never ending list!
Old Mar 3, 2010 | 06:11 PM
boostedpower's Avatar
Exclamation Motor Mount Issues... The never ending list!
Okay so right now I am doing this in my room, yes i have these oily *** parts in my perfectly clean house! so here is where I'm at, I removed one of the motor mounts cleaned it up, and took it apart, and now I am at a loss as too how I remove these old bushings, I was thinking about a long socket and a vise, but I wanted to see what you guys had to say first... need that insider know how! Maybe a little ?!?!
Thanks again guys, know I am pain, I promise the Build is almost done!
And of course Pics ------>
Side #1, Motor Mount Bushing #1
Side #2, Motor Mount Bushing #1
Old Mar 3, 2010 | 06:15 PM
jaycenk's Avatar
supposed to drill the rivits
Old Mar 3, 2010 | 06:16 PM
jaycenk's Avatar
What are you replacing them with? Polly?
Old Mar 3, 2010 | 06:22 PM
Prothane Motor and trans mounts, and my trans mount is deff, bad my shifter is jumping ALL THE EFF AROUND... feels like it just wants to jump into the cabin LOL
Old Mar 3, 2010 | 06:27 PM
drill the rivets? Im not really understanding this?! It did come with a few screws and 2 zipties? Are you sure I am supposed to drill the rivets out? Pics ---->
Thanks!
Old Mar 3, 2010 | 06:34 PM
nik1703's Avatar
just take a drill and jam it in there until the rivet denigrates
Old Mar 3, 2010 | 06:35 PM
jaycenk's Avatar
yes just did these last week. drill out those rivits and take out the old ruber. On the driver side you will use ALL of the nuts and bolts. the zip ties are for the passenger side. The three small bolts go in the bottom of the driver side mount and the 2 larger go in the top of the driver side mount. the two zip ties go one in the top of the passenger and one in the bottom.
Old Mar 3, 2010 | 06:36 PM
jaycenk's Avatar
Oh and when you bolt them in the car the ties will no longer be needed
Old Mar 3, 2010 | 06:38 PM
Robs94z's Avatar
Thats the right way to take them apart. Thats why they came with bolts, to hold the clam shell together where the rivits went. There should be directions with the new mounts explaining everything.
Edit- ^ Those guys beat me to the answer.
Old Mar 3, 2010 | 06:57 PM
Is this the passenger side? and do I need to drill out those two holes (I am assuming are rivets? here's a pic of where I at! ----->
Old Mar 3, 2010 | 07:15 PM
jaycenk's Avatar
pic shown is the driver side and you dilled the 3 on the bottom as I can see and yes those are kind of rivits , yes drill the top 2.
Old Mar 3, 2010 | 07:16 PM
Thanks Guys!
Old Mar 3, 2010 | 08:46 PM
Does this look right to everybody? --->
Old Mar 3, 2010 | 08:59 PM
litch2004's Avatar
sure does.
Old Mar 3, 2010 | 11:35 PM
jaycenk's Avatar
you need to show a pic of the side view so we can see the actual polly. it has to go in a certain way.
Old Mar 3, 2010 | 11:36 PM
jaycenk's Avatar
never mind I see the tabs, looks good
Old Mar 3, 2010 | 11:57 PM
gregrob's Avatar
Grade 5 fail
Old Mar 4, 2010 | 12:14 AM
litch2004's Avatar
boostedpower i dont mind help people out, just like others, but your motor mounts didnt come with any instructions? I replaced mine out a few months ago and the instructions were word for word on how to do this. It takes a lot of the guessing game out of it. Just figured i would ask. My kit did not use the zip ties at all. My instructions stated that they were for a different design motor mount housing. My kit came with bolts and nuts for both sides.
Old Mar 4, 2010 | 02:47 PM
Old Vs New Now, The drivers side mount bushing was dry rotted and had tears in it, the passenger side was alot better but still had some dry rotting and some tears (minor) pics before and after, and some in between! ---->
Before:
Passengers side (no oil clean up) --->
Drivers side (after oil clean up!) --->
Old mounts:
New Mounts:
Old Mar 4, 2010 | 02:57 PM
Originally Posted by gregrob
Grade 5 fail
Ehh Thats why they made the show are you smarter than a fifth grader and yet no1 has been able to win the cash... Sad sad times we are living in... also I spent every last dime that I have on this "project" so I can't really afford to make any mistakes, and (litch2004) about the motor mounts, maybe someone has figured a way to Switch out the old mounts without having to drill the rivets out while the mount is out of the car(who knows maybe with a ton of grease?!?) the point is if you have the knowledge in your head, is it really that big of a deal to help a guy out and submit a post that will literally take you less than a minute to respond to? I mean after all you did read my tread...
But I thank you guys for your CONTINUED SUPPORT in my project and to those of you who's time I wasted, I apologize that you won't get your 5 seconds of your life back from reading my tread... really...
