Just Got This Ad From Summit
Old Mar 4, 2010 | 03:41 PM
djjab57's Avatar
Question Just Got This Ad From Summit
Are these new heads or the ones that have been out ?
http://www.summitracing.com/search/B...KU&mbid=100387
Old Mar 4, 2010 | 03:43 PM
djjab57's Avatar
Looks like they will be having some sort of sale one a month for parts on our cars
http://email.e-mailnetworks.com/ct/1...B3E006CB675797
The ad also said this
Welcome to the Summit Bulletin: LT/LS Edition!
Here it is—your ultimate guide to pushrod performance! As a fan of modern muscle, you already know a thing or two about GM’s legendary LT and LS engines, and now we’re handing you the keys to unlock the huge tuning potential of these remarkable small blocks. Throughout the year, the Summit Bulletin will keep you up to speed on powerful LT/LS bolt-ons and essential tools, plus exclusive savings opportunities you’ll only get at Summit Racing Equipment!
Old Mar 4, 2010 | 04:51 PM
BLWNLT1_T/A's Avatar
Yea I just got it to... 430hp top end should be fun for who ever decides to get it.
Old Mar 4, 2010 | 05:06 PM
MasterTomos's Avatar
Nice looking kit, but looks to be a little pricey when compared to the performance you'd get on Port and Polishing the stock heads with AI or LE...
Old Mar 4, 2010 | 05:13 PM
djjab57's Avatar
Not really cause your getting gaskets rockers push rods ARP bolts and other things. Once you add that to an LE (which i have ) or AI heads it is pretty close
Old Mar 4, 2010 | 06:49 PM
1redta's Avatar
the cam in the "430 hp" is a wee bit bigger than a hotcam. BORING
Old Mar 4, 2010 | 07:11 PM
96capricemgr's Avatar
Are you considering that 430hp is FLYWHEEL, gross, STD. Make that rear wheel net, SAE and the number could easily be 100rwhp lower, maybe more.
One popular LT1 builder sells 440hp engines that make roughly 325 at the wheel behind an A4, the highest engine dynoing setup I have seen from him was 540fwhp and only 418 at the wheels and that was a solid roller LT4 stroker so that was not a good number.
Old Mar 4, 2010 | 07:35 PM
fergymoto's Avatar
Come on Dwayne we can just say Golen lol
Old Mar 4, 2010 | 08:04 PM
The point was many people do not understand the losses from flywheel STD to rear wheel SAE and get all impressed by a flywheel number.
I am sure the Trickflow package is quality parts, just don't want anyone mistaking it for comparable output to a ported heads package.
Old Mar 4, 2010 | 08:50 PM
mdacton's Avatar
agreed.
people will buy this kit and end up with a turd.......
$2500 could do alot mor good putting work into the stock parts....
Old Mar 4, 2010 | 09:43 PM
jaycenk's Avatar
I called trickflow about those heads when they first came out. They claimed 500hp out of the box. I asked for a cam recomendation. The guy said we just came out with a topend kit and I asked what will it make power wise? he said 430hp on stock bottom end. I asked him how they tested it and claimed they had a test car. BS When I asked them to recomend a cam to make 500 on a 383 he said I have to give the number to Advanced induction. I asked why they claim 500hp out of the box if they had no idea how to make it? no response, just call AI and they will tell you. bs AI was still using the older head. doubt it makes 430 since they don't really seem to have any info on what intake they used(lt1 or other) or injector size, or tuning info. I doubt it was real world tested on anything but a flow bench. I went LE
Old Mar 5, 2010 | 07:50 AM
As already covered the 430hp number is an ENGINE dyno number and a REALLY REALLY easy one to hit.
You talked to the equivalent of a receptionist and neither of you understood much.
Again I think money is better spent on porting but this is a much better option for the catalog shoppers than the Edelbrock stuff.
$350 less and comes with rockers, guideplates, and fasteners you will need. Granted the Edelbrock has an intake with it BUT it is an intake that all indications seem to be it is NOT an upgrade.
Old Mar 5, 2010 | 09:18 AM
JoeliusZ28's Avatar
has AI stated a time frame in which porting will be available on these new heads?
Old Mar 5, 2010 | 06:41 PM
Originally Posted by mdacton
agreed.
thank you...
LE and AI can put down over 400whp AT THE WHEELS with factory reworked heads...this kit has 430 Flywheel HP...big difference, and I don't care what else the trickflow kit comes with...it still makes worls less power than a good LE2 setup.
