tapped into temp sensor wire now it wont start
Thanks, Chris
http://shbox.com/1/temp_sensor2.jpg
Tapping the O2 wiring will undoubtedly cause resistance issues which the PCM will likely pick up and set an SES light, messing with what would otherwise be accurate readings. If you're looking for an A/F gauge, the best thing to do is to add another O2 sensor bung/wiring (or two).
It is generally unwise to tap into most critical engine sensors used by the PCM (water pump sensor, O2s, etc.).
The 3 wire still send a signal to the ECU and the third wire can make the after market gauge to work.
I have aftermarket gauge hooked up to the sensor on the left side cylinder head and the Factory ( Mazda in my case ) gauge hooked up to the new 3 wire sensor on the waterpump.
also for the air fuel gauge can i get any o2 sensor. so a single wire o2 will prolly be my best bet considering it will only be for the gauge.
You need a wide-band specific O2 sensor. A narrow band sensor (OEM replacement) won't work.
You could remove the factory coolant temp sending unit from the driver side cylinder head and use that port if you want.
As far as the temp gauge you can always buy a mechanical and tap into the passenger side cylinder head.
