need help finding out bolts
The thought is this:
Most bolts are really obvious as to their identity by just looking at them. Chances are, you won't confuse main bearing bolts with intake manifold bolts. Or flywheel bolts with exhaust manifold bolts...even moreso if you have headers.
If it's not obvious by appearance, it probably will be by count plus appearance. Certain bolts are almost always used for specific applications, like the shouldered bolts for a flywheel. Got 8 holes in a fairly thick flange? Got 8 shouldered bolts? BINGO!
On those occasions where there is still confusion, go by the bolt marking plus count plus appearance. Does it make sense to have a grade 8 fastener holding the water pump on? Probably not.
Does the amount of bolt sticking out of a long reach make sense as you are tightening it? You need to have enough thread engagement to allow tightening, which will probably be more than just one or two. By the same token, does the bolt bottom out before it's tight? You got it in the wrong hole, then.
Trust me, you won't see any plastic bags/markers in the average repair shop. Nor in any dealer shop. The flat rate manual doesn't allow for it.
But, I haven't turned a wrench professionally in many years (like 15+)...and I still use the bucket, and did from day one. I guess it's like riding a bicycle. You never forget how.
If you really want to get **** then go to this site and download the manual. It will tell you the size of every single bolt on the f-body that you need to know.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
3. is for your pressure plate
5. look like some sort of susp. bolts.
7. looks like tunnel cross member or transmission crossmember bolts.
8. and 9 may be for waterpump
10. looks like head bolts. Looks as though they have tap into water jackets judging by the crap on the threads.
11. is a starter bolt.
