383. build questions
Roughly 3k for the rotating assembly. Another 750 ish for machine work.
Its hard to give you advice without knowing what your main objective is.
1780 for a forged rotating assembly with arp 2000 rod bolts
around 800 for machine work
300 for custom cam
70 timing chain
175gasket kit
255 moroso oil pan
100 oil pump and pickup tube
85 eagle splayed main caps
50 arp main bolts
85 keyed balanceer hub
70 tci flexplate (nuetral balance)
IT depends man are you doing the work or not? My shortblock alone cost in the neighborhood of 5 g's. My heads only cost close to 4. You can make badass power with a stock set of heads with the right head porter( cough , cough, Lloyd Elliott, cough) have him custom spec you a cam. I would suggest 11:5:1 to 12:0:1 compression for pump gas with the right tuner ( cough , cough, Moe Bailey, cough)
Sorry got a cold
