getting alot of water in pass. valve cover.need help?
Long story short, on my 93' ta, I put a filter on the valve cover about 4 yrs. ago,I just took it off about 3 months ago because it was building up alittle crankcase pressure, causing it to leak oil I believe out the timing cover, anyways I put a elbow on it and ran it to my holley 58mm t.b. out the nipple on the side of the t.b. anyways Im getting alot of water condensation in the valve cover now, I just took off the pass. vc about 3 weeks ago, and cleaned it out, it had alot of white milky,thick gunk in it, and on the roller rockers. and I just checked it again, and same thing, I cleaned it out, and took off the hose off the t.b. and water dripped out, I took off the elbow on the vc and put in a pcv valve, will this stop condensation from getting in the vc? and if not, Im curious why Im getting water in there? the cai is not getting water in it. it is a ram air setup. here is a pic of how I have the hose ran, is this right? thanks for any help.
Naw Im pretty sure it's water, because it's coming from the t.b. and it's pure water,no antifreeze at all.oil is clean as is coolant. Car is not smoking,not missing, no coolant smell, I can tell it's coming from the t.b., there has been alot of rain lately maybe somehow water is getting into the t.b. from the cai? Im just curious if the pcv valve will also keep the water out, or maybe it's time for a catch can.
I did the t.b. coolant bypass yrs. ago, I don't believe it's the line.
I don't have the vararam on the my ta. it's on my goat. here is a pic. of the ram air setup...
here is the t.b. nipple that I have the valve cover hose running to..
Maybe it's just alot of condensation since it's been winter. Well now spring.
That's the way I will go. Becuase Im getting so much in there, I can take off the oil filler cap and rub my finger around in there, and by the rr's and it looks like I come up with a teaspoon of mayonaise.
Yeah I gave the car to my son. "17". and I know he probably doesn't let it war up enough.Im not around when he leaves, but I bet he doesn't let it warm up for then 30sec. to 1min. before he leaves. Plus he only drives about 3/4 mi. then he's at school and he shuts it down.In our small town, he doesn't get over 30mph.
Why on earth has no one mentioned anything about there being a PCV valve in the valve cover?
TAKE IT OUT.
That tube is merely a supply hose for the crankcase for the actual PCV valve (located on the driver side of the intake manifold). With the fresh air supply hose restricted by a PCV valve, the ACTUAL PCV valve doesn't have any negative vacuum to function properly and burn off the crankcase gases, promoting a build-up of moisture and sludge.
Once you remove the PCV valve, then you should start to see a decrease in crankcase moisture, but not entirely. It is normal to have a small amount of condensation in the crankcase.
TAKE IT OUT.
TAKE IT OUT.
TAKE IT OUT.
