How important it the air dam?
Imagine all of the surface area of parts under the vehicle. Engine, transmission, suspension components, floorpan, axle fuel tank, exhaust, etc. etc., all of these parts (without the air dam in place) will provide some kind of wind resistance depending on their location and orientation. The air dam reduces the amount of flow under the car and redirects it towards a more useful area - into the radiator.
Less airflow under the vehicle = less drag.
Personally, I'd believe modern racing methodology, fluid dynamics, and aerodynamics - not some guy on a forum. My air dam stays on.
JMHO, of course.
Just goes to show, the interwebz is full of stupidity and people will believe it.
JMHO, of course.
edit: just another point, a front splitter pushes more air up & over the nose creating a high pressure spot, creating more down force on the nose.
mitch is no idiot, but how could we expect a newb to know who the experts are on the site. edit: I take that back in part just glanced at your post count, and now I see your join date.
Where's yours?
I went from stock to the aforementioned mods (except the splitter), and saw a huge improvement at all speeds, especially north of 140. I'm running Strano springs/bars, Konis, and Mitch's alignment specs, but I left the isolators in the rear to keep it a bit high, and then put the front Konis on the lower perch to drop the nose more. I originally trimmed the air dam bc it would scrape on everything, and some people told me it would hurt aero, but I actually think it helps. It doesn't seem like its in the right location to help aero; it just forces air up to the radiator and creates high pressure under the hood which creates lift and hurts handling. My logic might be off, but my car is rock solid at speed (and doesn't overheat either).
F-bodies have terrific drag coefficients of .34 for both the Pontiac AND Chevrolet (same as a Porsche 911, Ferrari 360 Modena, Aston Martin DB9, etc.) The "not-so-great aeros" comment is opinion.
He says you "should see improvements." Once again, opinion, not based on fact or scientific evidence.
He also says "I actually think it helps." Once again, opinion, not based on fact or scientific evidence.
Then, "It doesn't seem like its in the right location to help aero; it just forces air up to the radiator and creates high pressure under the hood which creates lift and hurts handling. My logic might be off, but my car is rock solid at speed (and doesn't overheat either)."
OPINION. "Doesn't seem like its in the right location to help aero" isn't too much of a convincing argument. Not to mention, he isn't even confident of his own conclusions! "My logic might be off" - that's real convincing.
It's also ironic that on that webpage you referenced...every 4th gen vehicle has an air dam.
Bye bye!
if it makes your front end lift at 70mph why are there so many stock bodied drag cars running 150-210mph and not taking off like planes..lol
leaving it in there scoops the air up at speeds and drives it into the engine bay..so now your craming air into a engine bay where there is no where near cubic feet in exit holes for the air to escape out of..
will that cause your front end to have a tad more down force yes...will it be enough to really matter and delete the turbulance going on inside the engine bay from you ramming air into it no..
