question on cam
Old Apr 9, 2010 | 06:24 PM
Big bird55's Avatar
so the 503 is to much for just a stock head car with lifters rockers pushrods and springs
Old Apr 9, 2010 | 06:57 PM
qc97z's Avatar
Originally Posted by bigj2717
Haha and then another grand or some to send them to someone else to fix them and do it right.
Actually, yes, $100. And he's been porting heads for decades. He ported heads for both my father's alcohol-injected big block dragsters. Fastest in his class.
Just because nobody does a decent job for cheap near you...doesn't mean old guys don't do a good job elsewhere.
Old Apr 9, 2010 | 07:21 PM
BigBadWhitey's Avatar
I second this. Theres this old bugger here in town who can tune a holly 4 barrel double pump by ear, ports stock-> drag car heads, and doesnt charge 1000 bucks to have them run through a machine and tell you they flow this much, cuz they put a set through the same machine and they flowed said ammount. He did a set of LT1 heads for a guy around here for 400 bucks, and they flowed in the 275/280 intake range. Everyone on forums is some kinda fanboy. Everyone will scream AI or LE, and wont even have the product they push on their car.
Old Apr 10, 2010 | 01:12 PM
Big bird55's Avatar
so the 503 is a good cam to run on stock heads?
Old Apr 10, 2010 | 05:01 PM
RamAir95TA's Avatar
I don't even know what to say. I guess I wasted my $2500 on AI heads.
*sad face*
Old Apr 10, 2010 | 06:15 PM
myltwon's Avatar
Originally Posted by Big bird55
what was all doen to that car to make it sound like that any motor work? were would i get that cam new thanks
just intake, midlength headers, slp loudmouth, 1.6 rockers, 10308-1 crane spring kit more or less
Old Apr 10, 2010 | 06:29 PM
gixxer75094lt1's Avatar
yes perfect for stock untouched heads just change the springs.
Old Apr 12, 2010 | 10:20 PM
Big bird55's Avatar
ok what about this cam
TPiS ZZ409 226/226, .525/.525, 112 LSA good cam?? i am leaning on the 503 but i coul dget that one for 125 shipped to me
hwo much does a new 503 go for and were can i order it thanks guys
Old Apr 12, 2010 | 10:21 PM
Big bird55's Avatar
heres the video of the tpis
http://www.youtube.com/watch?v=pJeS1...ayer_embedded#
Old Apr 12, 2010 | 10:28 PM
myltwon's Avatar
from what I've seen LT1s don't respond as well to single pattern cams as dual pattern cams
don't pick a cam based on its idle clip you found on youtube, look for people with real results and experience
Old Apr 12, 2010 | 10:32 PM
z_speedfreak's Avatar
food for thought, 230/238 on stock heads:
Originally Posted by chavez885
Not a ton of info out on this cam so thought I'd post up. Here's what she made, mods below hopefully did not forget anything... Pretty happy with it, car runs great and I could not ask for a better mail order tune. Lot's left to do, it needs gears BAD, already have some radials, waiting on new rear then she'll see the track!
Mad Z28 mail order tuned
Old Apr 12, 2010 | 10:39 PM
  #32
gregrob's Avatar
That AI cam was on a rebuilt motor with bumped compression.... Don't expect that tq curve on a stock long block...
Old Apr 12, 2010 | 10:43 PM
  #33
CamaroRacing12's Avatar
yea he said 11.1 compression. is that a good streetable compression? all he did was change head gaskets
Old Apr 13, 2010 | 12:02 AM
  #34
no big deal, when your doing the cam its not much more work or money to swap the HG's and obtain 11:1
yes, its the dcr that matters. roughly estimating here.. I run .029 gaskets(11:1scr) and the heads have been milled .010 so my scr should be somewhere around 11.2/11.3 but my dcr is around ~10.2:1
Old Apr 13, 2010 | 12:06 AM
  #35
RamAir95TA's Avatar
Running race gas, are ya?
Old Apr 13, 2010 | 12:16 AM
  #36
bombebomb's Avatar
There's a guy in my area that will port a set of heads for $100.
Tell us the #'s when you get it dyno'd if you hit 420whp, every lt1 owner in 2000 miles will flock like ducks.
That is some high DCR for a street car, what octane do you run?
Old Apr 13, 2010 | 12:19 AM
  #37
no need. If that seems high(tho I've some where read 93 can handle 11.25dcr?) then maybe I calculated incorrectly. regardless 11:1 is AI's(and LE on his cams) recommend scr and being milled .010 is only another **** hair of static compression. cam in sig int closes @ 42.7ABDC(@.050) and I'm @ sea level if u want to calculate
Old Apr 13, 2010 | 12:33 AM
  #38
bombebomb's Avatar
I think you have all kinds of stuff mixed up, but I failed math, what do I know.
Old Apr 13, 2010 | 12:40 AM
  #39
eyeahh math wasn't my strong subject either lol
if anyone else wants to take a stab @ calculating my dcr all the other variables (#of cylinders(obviously), stroke, bore, cr length, & boost(0)) are all stock
Old Apr 13, 2010 | 10:53 AM
  #40
gregrob's Avatar
You do not have 10+ DER
