question on cam
Old Apr 13, 2010 | 11:14 AM
  #41
z_speedfreak's Avatar
Originally Posted by gregrob
You do not have 10+ DER
then I calculated wrong I kno your pretty knowledgeable about this stuff, care to take a stab at it? I've tried calculating it 3times and always get the same thing so I'm doin somin wrong
Old Apr 13, 2010 | 11:25 AM
  #42
gregrob's Avatar
PM me your specs. bore, hg thickness, how much heads were milled etc
Old Apr 13, 2010 | 07:43 PM
  #43
thehammer69's Avatar
Originally Posted by Big bird55
ok what about this cam
TPiS ZZ409 226/226, .525/.525, 112 LSA good cam?? i am leaning on the 503 but i coul dget that one for 125 shipped to me
Shitty...
Old Apr 13, 2010 | 07:46 PM
  #44
Originally Posted by z_speedfreak
no need. If that seems high(tho I've some where read 93 can handle 11.25dcr?) then maybe I calculated incorrectly. regardless 11:1 is AI's(and LE on his cams) recommend scr and being milled .010 is only another **** hair of static compression. cam in sig int closes @ 42.7ABDC(@.050) and I'm @ sea level if u want to calculate
You need to calculate your DCR using SEAT IVC instead of ADVERTISED IVC.
Old Apr 13, 2010 | 10:01 PM
  #45
Big bird55's Avatar
any ideals on were to get a good used 503 ??? dotn want to spend that much to buy it new but i will if i have to
Old Apr 13, 2010 | 11:02 PM
  #46
dude...get the lunati cam that is 218/227 and have a car that is extremely fun to drive. Don't get caught up in the BS of bigger sticks.
Old Apr 13, 2010 | 11:09 PM
  #47
JB_97ws6TA's Avatar
219/227 @ .050 Lunati 60121 and yes that cam rocks
Old Apr 13, 2010 | 11:11 PM
  #48
SS MPSTR's Avatar
sweet cam that will be fun to drive and easy on valve train parts.
  #49
yeah, that one...
Old Apr 13, 2010 | 11:17 PM
  #50
JB_97ws6TA's Avatar
I don't know about easy on valvetrain parts but it certainly doesn't beat the hell out of them. The lobe profile is actually pretty nasty on that cam, it has really fast ramp speeds but lets that valve back up fairly easy.
Old Apr 13, 2010 | 11:45 PM
  #51
SS MPSTR's Avatar
Aggressive opening (within fair range w/out lofting the lifter off the lobe) is far better than aggressive closing!
Old Apr 14, 2010 | 01:02 AM
  #52
BigBadWhitey's Avatar
What kind of DCR is to high? Im liking the specs on that lunati 60121 but its looking like ill be getting a DCR of about 9.7:1 with the heads and whatnot i want to use. Is this too high?
Edit: Should mention its a full street car, no track.
Second edit: Does anyone know the stock cam ABDC?
Old Apr 14, 2010 | 01:22 AM
  #53
enjoi355's Avatar
http://www.empirenet.com/pkelley2/DynamicCR.html
Old Apr 14, 2010 | 02:40 AM
  #54
Ok then im confused, with stock components doesnt that cam make a DCR somewhere in the range of 9.7:1?
Old Apr 14, 2010 | 08:06 AM
  #55
yeah thanks, gregrob was just explaining that to me.. looks like I was doing a few things wrong
whitey- looks like your doing some things wrong too considerin my dcr is ~8.99, j-rod has a calculator you can DL in the adv tech section ...which I couldn't get to work w/o excel but u might have better luck.
Old Apr 14, 2010 | 09:04 AM
  #56
1961ba427's Avatar
There used to be one on Comp Cams site too. Very easy to use as long as you know the IVO/IVC, EVO/EVC timing events. These are usually lost with the cam card.
Old Apr 14, 2010 | 09:39 AM
  #57
You want to know the real kicker...even if you know the cam card specs, your calculation is still only a approximation of what it really is. The fact is, cams are rarely ground spot on to the book spec. Unless you have your cam put on a cam doctor or similar device, you won't know if your cam grinder ground in more or less advance...or if you didn't get your LSA ground at what you ordered. Or even if your seat duration is larger or smaller than what it is supposed to be.
This is why if I spec a cam for somebody, i require them to pay for an Adcole report. I have returned a cam to Comp because their own Adcole machine reported what was ground for me was significantly out of spec for what I ordered.
And since I am off on a tangent here...Sometimes, out of spec grinding works for you too. Gregbob's cam came different then what we ordered, but it actually worked out better. So we used it and it has worked great in his car.
Old Apr 14, 2010 | 02:25 PM
  #58
how much was greg's cam off by?
Old Apr 14, 2010 | 04:09 PM
  #59
Big bird55's Avatar
i am not caught up in all that. thanks for the other cam idea. i just want to get biggest cam i can run so i can be cam only. that cam is nice but i want some thing to hit a little harder but this is oen of the possiblities
Old Apr 14, 2010 | 05:09 PM
  #60
gregrob's Avatar
