Car trouble!! again! :( I'll give some paypal cash to whoever solves my problem 1st!
I just got the codes checked out and I only got one code: P0134 Oxygen Sensor Bank1/Sensor 1 no Activity. The check engine light has been on for at least 2 months as I always just ignored it. One thing I did forget to mention was that when it would rev up by itself I did hear a backfire on the exhaust.
If you are having a "no activity code", then you NEED to diagnose that first. That WILL cause the concern that you are having. The pre-cat sensor monitors engine performance and if the ECM is not seeing any activity then it is going to default to a constant rich/lean condition. Check and make sure that you have proper voltage, signal and good ground at the connector, if so then replace the sensor. As far as everything else, I wouldn't say that it would be your T/B sensors because cleaning it rarely creates problems, however, cleaning your MAF sensor almost always screws something up. They are VERY, VERY sensitive and are not to be cleaned without the proper solvent, and even then it get tricky. That is what I would do if you came into my shop... Good luck!
When i cleaned my maf, one of the three wires broke after the connector, inside the bundle of wires.spliced and soldered , this solved my problem.,good luck
#32
As far as modding, no I havent done anything to the car lately. I did clean out the throttle body and mass air flow sensor though, other than that, thats it, it still had the same result before and after cleaning them so I dont think I screwed anything up that time.
There is your problem. I accept checks
