Car trouble!! again! :( I'll give some paypal cash to whoever solves my problem 1st!
Old 04-12-2010, 12:45 AM
emj2006's Avatar
Default Car trouble!! again! :( I'll give some paypal cash to whoever solves my problem 1st!
Ok so it all began 2 days ago, it was running fine and normal, then all of a sudden I came to a stop and the idle starts to surge. Then the next day it would get worse as I could smell the exhaust and could definitely tell that its not getting proper combustion. The idle would surge not the entire time when Im at a stop, just consistently. Today, it was doing the same thing, and it was even revving up by itself at a stop . It would fluctuate between 800-500 rpm and even rev up to 1000 rpm and then go back to the 800-500 rpm range. Any ideas out there? I'll be checkin my check engine light tomorrow to see what pops up.
Old 04-12-2010, 12:47 AM
ssman00's Avatar
some info on the car would help. year, engine, mods, history?
Old 04-12-2010, 12:52 AM
JB_97ws6TA's Avatar
first off are there any codes??
Old 04-12-2010, 01:14 AM
emj2006's Avatar
yes there is a check engine light on, I'll get the codes tomorrow. Mods are Pacesetter LT's, Ram Air conversion, replaced with MSD opti and NGK plugs about 2000 miles ago, and it also got the mailorder tune by madtuner.
Old 04-12-2010, 01:15 AM
emj2006's Avatar
its a 1996 t/a also,
Old 04-12-2010, 01:18 AM
JB_97ws6TA's Avatar
maybe jumping the gun a little bit offering up a reward for a solution to a problem that you haven't begun to troubleshoot yet Pull those codes and go from there.
Old 04-12-2010, 01:25 AM
WhitePhoenix99's Avatar
Have you done anything to the car recently? As in like the past day or two
Old 04-12-2010, 01:27 AM
emj2006's Avatar
As far as modding, no I havent done anything to the car lately. I did clean out the throttle body and mass air flow sensor though, other than that, thats it, it still had the same result before and after cleaning them so I dont think I screwed anything up that time.
Old 04-12-2010, 01:33 AM
9Green-Z8's Avatar
i might be one of your sensors tb or maf just scan it and let us know
Old 04-12-2010, 01:34 AM
So the problem was occurring before you cleaned your throttle body/maf? My car did something similiar when the shampoo bottle cap came out from my intake elbow. Do u still have the stock elbow with the donkey dong attached?
Old 04-12-2010, 03:14 AM
jay7199's Avatar
Map or tb sensers get my vote.
Old 04-12-2010, 06:53 AM
STOCKTA's Avatar
Throttle position sensor gets my vote also! once on the scan tool the force will guide you
Old 04-12-2010, 07:03 AM
blackodium's Avatar
waiting....
Old 04-12-2010, 08:02 AM
WARDOG's Avatar
I have the same problem but mine surges from 1k to 1.5 rpm it threw code p0100 and another one i cant remember. I gotta find a shop that has a good scanner that can look at all the sensors to see which one is messing up. Let me know if you find the problem first ...
Old 04-12-2010, 09:08 AM
mike171562's Avatar
Sounds like your IAC motor on your throttle body, if it has trouble finding a good idle spot.
Old 04-12-2010, 09:34 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
Mine acted like that a looong time ago. I had a deteriorated vacuum line (vacuum leak)
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 04-12-2010, 10:08 AM
94fixerTA's Avatar
Either a bad vacume line or tps problem.
Old 04-12-2010, 10:37 AM
emj2006's Avatar
I just got the codes checked out and I only got one code: P0134 Oxygen Sensor Bank1/Sensor 1 no Activity. The check engine light has been on for at least 2 months as I always just ignored it. One thing I did forget to mention was that when it would rev up by itself I did hear a backfire on the exhaust.
Old 04-12-2010, 11:11 AM
94fixerTA's Avatar
I would check the throttle position sensor.
Old 04-12-2010, 11:13 AM
Restricted User
z99ls1's Avatar
Mine did the same thing when my opti was going out on my 93. The rpm's kepted on moving just like you described when it was idling
Quick Reply: Car trouble!! again! :( I'll give some paypal cash to whoever solves my problem 1st!
