Guide to installing an LT1 Help?!
Old Apr 21, 2010 | 10:10 PM
94zGreen's Avatar
Default Guide to installing an LT1 Help?!
This is a diy project and I was wondering if anyone had a guide to putting an LT1 into a 4th gen.
Help would be greatly appreciated.
Old Apr 21, 2010 | 10:50 PM
94fixerTA's Avatar
"How to Rebuild Small Block Chevy LT-1/LT-4 Engines" by Mike Mavrigian. This book you can get from barns and noble. I was told it's from pulling the motor to installing it how to.
Old Apr 22, 2010 | 07:19 AM
shbox's Avatar
It's just an engine rebuild book. Nothing about pulling or installing it.
94zGreen: doesn't your Z already have an LT1? There are tons of threads around and some guides about pulling the engine.
Old Apr 22, 2010 | 07:22 AM
94zGreen's Avatar
no, i sold my green Z, and i bought a black roller car. We have the engine me and my bro just need a guide to help us put it in.
Old Apr 22, 2010 | 07:36 AM
Z28Roxy's Avatar
Put the engine and trans on the kmember / front suspension.
Lift the car up with an engine hoist.
Put the car on jackstands which are on top of wood lincoln log stacks.
Put the engine/trans/suspension underneath the car.
Lower the car on to the engine/trans/suspension. Bolt up the kmember and shocks to the body.
This might give you some ideas:
http://www.michiganspeed.com/enginepull/index.html
Old Apr 22, 2010 | 07:54 AM
94zGreen's Avatar
Thanks Z28Roxy, this might help a little. i didn't know if anyone had like a good step by step to get it all in and what not, but this might work too. Thanks!
Old Apr 22, 2010 | 11:14 AM
myltwon's Avatar
1) set motor in car
2) put everything back how you found it
3) enjoy
honestly though the wiring harness is pretty self explanitory everything is only as long as it needs to be so as long as you route it the right way it'll pretty much go where it needs to be, though only real PITA was installing the accessories because I did them after the motor was in
Old Apr 22, 2010 | 04:44 PM
94zGreen's Avatar
the problem with putting everything back where i got it is that it came with no motor, sooo.
Old Apr 22, 2010 | 05:13 PM
BlackBird87's Avatar
I bought a roller with the engine and trans sitting next too it. and with no prier knowledge of lt1s everything went together pretty easy. I thought it would be alot harder then it really was.
Old Apr 22, 2010 | 05:28 PM
JB_97ws6TA's Avatar
I would just get going on it and ask questions as they arise, it is pretty straight forward
Old Apr 22, 2010 | 05:31 PM
AChotrod's Avatar
A happy hooker goes along way installing a motor
