Want to build a 500 HP LT1
#62
So, tell me, if you were in my position, what would you do? I've got a solid LT1 bolt on motor right now, but I've got 200.000 K on it, and need to refresh it. I want some serious power, but don't want to sacrifice reliability, and will honestly, rarely, if ever see the 1/4 mile.
Is a hot top-end all I need?
Sorry for all the "all over the place" questions, guys, but I'm not an engine pro. I'm a painter, I love the cars, but know jack s**t about building power!![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Refresh the block and throw some ARP rod bolts on it and go with an LE or AI matched topend and you will be 400+rwhp in a totally reliable, streetable car. Good for 11s with supporting mods...plenty fast enough for a car that will admittedly see very little track time
Like roxy said though, if you think you might want more later, building the bottom end strong wont hurt, and will open the options up a ton down the road...but will be significantly more expensive.
#63
#64
Bore it .030
Forged pistons
Balance
Arp rod, main and head bolts
square deck it
New rings,rods,mains and oil pump
Topend of your choice.
Go have fun
#65
Village Troll ![](http://jameskellock.tripod.com/sitebuildercontent/sitebuilderpictures/rsman.jpg)
For a stock stroke/heads/cam/N/A type build then rods would not be necessary. LT1 rods are some of the strongest you can buy before going forged. I'd suggest a reconditioned stock crank, rods, ARP rod bolts, hyper-u pistons (forged aren't really necessary if you are staying N/A).
#66
for this power level it is not worth the extra money to stroke it, imo at least. what is a typical gain over stock cubes - 15 to 20 peak and a bit more under the curve. and the ability to not have to purchase a new crank and rods will save you a ton of money, the money would be better spent on high quality top end components, which is where your power comes from. a good set of ported stock heads by AI or LE will be more than enough for a nasty street car
once you build a motor once its not very difficult to do it again (unless your wallet is doing the work), so if you want to pull it in a few years and build a fully forged stroker later you will already have the top end to handle it
#67
OP...
Man, I'd ditch the shorties... If the engine is getting tired, tear it down and rebuild/refresh... good 3 or 5 angle valve job, a good set of Long Tubes, Cam/Heads... and the a Strange S60 Dana Rear-end with a nice set of 4.10s... that's seven grand, right there. Add the forged internals and that's another 2500...
The ten- bolt is not going to handle 500 rwhp... PERIOD. It's not even debatable... despite the near certainty that someone will feel compelled to debate it.
I'm running an A4 and well south of 500 N/A-hp and rebuilt her 10-bolt twice; the last go around with an Eaton Locker.
So there's absolutely NO POINT in even THINKIN' about tearing into the engine, adding all that torque, when you're GOING TO detonate the diff' almost immediately.
The guys are exactly right... except most have under-estimated the costs; my experience puts the costs for what you're looking to do at around $12k...
If you've got the scratch, great... drive it up to your builder of choice and tstroke a check...
But if you're doing it yourself 5 grand at a time... start with the R&R, Headers... Rear-end... build the foundation before ya start decoratin'...
You'll have a blast...
#68
OP...
#71
I wouldnt trust a 10 bolt in a stock 6 speed car, but its amazing how long they last in autos...lol
If the shortblock is strong I wouldnt break the thing open, who says after cam and heads that you dont spin a bearing a month later from the newfound abuse the motor will surely take.
I don't know who it was earlier that said it, but he's right , put some long-tubes and some other supporting cast items in place and save up for the magical day the motor starts clacking. Then do as you please.
#72
I've fired off an email to Lloyd Elliot to get his take on things. Looks like an LE1 setup will really get me into a good HP area, and not break the bank. I think I'll remove the motor before adding the LE1 setup though, just to refresh the bottom end. Plus, my rear main is leaking, so gotta take care of that as well.
As far as the bottom end goes with an LE1 setup, you think stock will be OK? Just clean things up, put in some new bearings, piston rings, etc???
#74
ur an idiot. he said n/a hp....... so if yo want 500 to the ground i suggest you go with a solid roller set up with all the bolt ons including electric waterpump, lightwieght flywheel, etc. if ur looking for flhp i would say a set of trick flow 195 heads and a xfi 280 or 292 will get yoiu there. 11.0:1 plus or minus
