A/C delete question
Old Apr 22, 2010 | 09:13 PM
my95LTwon's Avatar
Default A/C delete question
I'm curious if there is a thread with a "checklist" of all the things to take off for A/C removal? I tried searching but came up with nothing. I also read somewhere that you can do a little fabrication and replace the A/C pump with the alternator and replace the alternator with an idler pulley, any info on this? Thanks!
Old Apr 22, 2010 | 09:32 PM
robsquikz28's Avatar
look below for your alternator relcation.
http://www.speedinc.com/catagory.cfm?catagory=Engine
Just remove the a/c and junk the rest!
Old Apr 22, 2010 | 09:34 PM
bufmatmuslepants's Avatar
Go to advanceauto and get an AC delete pulley, drop your compressor, and bolt it on. No fabrication. 2 bolts on the front of the compressor, 2 on the rear bracket, and 1 holding the rear bracket to the block. Start yanking AC parts like condenser and lines, youll drop maybe 30lbs.
Old Apr 22, 2010 | 09:44 PM
stburgpete's Avatar
your link does not work
Old Apr 25, 2010 | 04:54 PM
bore.me's Avatar
try this link: http://www.speedinc.com/catagory.cfm?catagory=Engine
Old Apr 25, 2010 | 09:57 PM
litch2004's Avatar
i have a write (sort or, more less pictures and info) that i have sent to other members to modify your factory accessory bracket to move the alternator down into the factory a/c compressor location. let me know if you would like this info.
Old Apr 25, 2010 | 10:03 PM
litch2004's Avatar
here are a couple of pictures to see if this is what you are referring to:
Old Apr 26, 2010 | 01:04 AM
my95LTwon's Avatar
Yeah, that looks great! I'm really wanting to clean up the passenger side of the engine bay for my long tube install soon. I'm hoping that it will make it a little easier without all of the a/c crap and alternator out of the way. Spill the beans!
Old Apr 26, 2010 | 04:32 PM
ttrimz208's Avatar
Originally Posted by bore.me
That was funny. Try this link.
http://www.speedinc.com/cont.cfm?cid=C0000986
Or this thread. This isn't cheap, but looks the best.
https://ls1tech.com/forums/lt1-lt4-m...or-ps-kit.html
Then make a panel and take out the heater box. Not necessary, but cleans things up.
https://ls1tech.com/forums/lt1-lt4-m...x-removal.html
Old Apr 26, 2010 | 05:48 PM
CamaroRacing12's Avatar
i wouldnt remove the heater box, u lose defrost and heat
Old Apr 26, 2010 | 07:22 PM
ttrimz208's Avatar
MERV shows how to keep the heat. There are a couple of others that have modded plates to allow heat.
https://ls1tech.com/forums/8437506-post8.html
Old Apr 27, 2010 | 01:57 AM
94camaross's Avatar
when i installed mine i went from the bottom. pretty painless. the only thing i had to move slightly was the steering linkage. tip about going from the bottom is to jack the front end up as high as you can. good luck!
Old Apr 27, 2010 | 06:35 PM
my95LTwon's Avatar
Yeah, the more I look the more it looks like it's not going to be as bad as some people make it out to be to put in the longtubes. I also have access to a lift and a shop so I guess I should have it pretty easy . I also just like the look of a clean simple engine bay. Coming from an 87 Mustang 5.0 I feel like every time I work on this thing haha.
Old Apr 27, 2010 | 07:24 PM
z_speedfreak's Avatar
I'm havin a hard time tellin from the pics,, what exactly did you have to do to make that work?
Old Apr 28, 2010 | 12:29 AM
suicidal racing's Avatar
looks like he used a piece of angle iron to mount the alt to it..but i would like to know what he used for the top pulley.
