Pull heads with cam?
Old Apr 26, 2010 | 10:47 PM
elis94camaro's Avatar
Default Pull heads with cam?
I was just wondering if anyone has swapped the cam without pulling the heads, did you later regret not pulling them because of a blown head gasket?Please give me the pros and cons because I dont want to take long on my cam swap.
Old Apr 26, 2010 | 10:48 PM
RamAir95TA's Avatar
The heads don't need to come off for a cam swap.
Old Apr 26, 2010 | 10:53 PM
thehammer69's Avatar
Cons of not pulling heads:
1. you are stuck with stock Static compression
2. you have to change valve springs anyway. Easier to do on bench.
Pros of not pulling heads:
1. You don't have to deal with hassle of pulling the heads
Old Apr 27, 2010 | 06:25 PM
ss.slp.ls1's Avatar
IMO the time and energy need to pull the heads, clean them up, and install new gaskets is not worth the ~3% gain in overall that you could get by bumping up the static compression by running a thinner head gasket and/or milling the heads. Of course you could always get a valve job done to and pick up a few more ponnies, but I would save all that for when you have the funds to send out the heads to be ported.
Old Apr 27, 2010 | 07:25 PM
z_speedfreak's Avatar
its really not that much more work imo to pull the heads..
Old Apr 27, 2010 | 07:26 PM
Mighty Whitey's Avatar
i didnt pull the heads when I swapped in my cc503.
my car has 103k miles on it, and I drag race it and raise hell in it on a regular basis without any problems.
now... if you were installing headers at the same time as swapping cams, I would most definately pull the heads. it's only 36 more bolts.
Old Apr 27, 2010 | 08:10 PM
dangalla's Avatar
Originally Posted by ss.slp.ls1
IMO the time and energy need to pull the heads, clean them up, and install new gaskets is not worth the ~3% gain in overall that you could get by bumping up the static compression by running a thinner head gasket and/or milling the heads.d.
in addition to compression change like stated before it is alot easier to change the springs on the bench, plus having fresh gaskets and arp head bolt is always nice, and it is really not much more work after getting the cam out
with that being said, you absolutely do not need to pull the heads to do the cam swap
Old Apr 27, 2010 | 08:43 PM
gregrob's Avatar
No reason to pull them unless you run a cam that needs the little compression bump...
Old Apr 27, 2010 | 08:51 PM
SexyTransAm's Avatar
ill be pulling mine to put new gaskets in when i do the cam. just cause the car has 127xxx miles and they might blow at any time and ill be pissed if i dont chance em now and they blow after i had it apart this much.
