What head gasket to use?
#41
he's only looking to spray a 200 shot guys. If he went custom he could bring the rings down some, and that would help, however with that 6" rod he might turn it into a bit of an oil burner. I definitely agree a new piston is in order however, unless he wants to take 10 cc out of those heads, if that's even possible....
#43
OK so would these be a better decision then????
SBC125030F05 4.03" 3.750 6.000 0.927 1.125 -5cc 406 11.1
I calculated these in the c.r calc and I got a total of 12.11 inputing a + number for valve reliefs?
lmk guys I really need to order some pistons and need to know will these handle a big shot?
#45
So I guess I will go with those pistons and .040" head gaskets and call it the day then correct.
I then can use my exact same setup with these above
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#49
didnt look at the part numbers and the actual pistons or ring land thickness, but, i've milled dome pistons for guys to drop their compression.
