I am done with Lt1/Camaros/Chevrolet
#41
my stock opti lasted 200,000 miles. i DD it for almost 25,000 miles in snow, rain, hot cold, never an issue until about 200,000 miles.
replaced it with a thepartsladi opti and put another 12,000 hard miles on it.
and i never babied the car either.. maybe i had a freak?
aaron
aaron
#42
Sorry OP, but welcome to the LT1 world! I've owned several LT cars and after my last '93 I finally decided to throw in the towel. If it's not one thing it's another with them, I swear, every little thing that can go wrong can and will go wrong in an LT1. The motors can make good power, but it's the reliability in them that makes for a big issue. Let's just say i'd never buy another LT-powered anything again.
#43
this is waht i have came up with.....
people who hate LT1s are people that don't work on cars on a day to day basis and then then they "Try" to work on it when it breaks; which ends up in a "I hate this Fu**in car I wish I had a ls1,thread" because something was hard to do... I work on cars every day and compared to other cars LT1s arent that dig of a deal... do a oil pan gasket/rear main seal on a Cadillac northstar and then say working on a lt1s are hard to work on...
![Rotflmao](https://ls1tech.com/forums/images/smilies2/rotflmao.gif)
#44
LT1's problem is that it is one of the most misunderstood engines ever made. An opti that is installed properly will never get wet. My stock unvented 1993 opti lasted for 90,000 miles. There's no doubt the LS1 is a more reliable engine x10, but an LT1 properly maintained can run forever with few problems.
#45
i sold my 94 ta with 212,000 on the bottom end! i put head gaskets on it at 185k, and an opti at 202k.
put over 30,000 HARD miles on that car. i beat the ***** off of it every day. i got 5000 miles out of my tires! donuts, burnouts, beating the ***** off it. but i kept it maintained.
screwing around, taking pictures cuz i was going to make a write up here.. it took me 3 yes three hours to take off the opti, take my time, clean the motor, put new one on, and get it running with air bled out of the system.
but i am by no means new to working on cars, but it was EASIER than what every one said it was.. and those ppl have either never worked on an LT1, or owned an LT1.
aaron
#46
Resident Racing Jerk
90% of the time, reliability issues will fall back on whoever has been working on the car. there is unmolested LT1's running around everywhere with no problems.
#47
Im a mechanic I work on many different cars every day and im good at it I make real good money doing what I do and I under stand that its not for every one, all I was saying is that I believe most of the people that "Hate" the LT1 motor have little or no mechanical ablates and when they try to do something they get frustrated and they blame the motor and they do not do not think it might be their own ignorance. working on a lt1 is no different then working on any other motor you just have to understand it....(which i think many people do not)
#48
My LT1s been pretty reliable and all my problems have stemmed from me working on it, its been a learning experience and Ive become pretty good at diagnosing and working on them.
I literally hit standing water on purpose when I drive mine, and I will get the underhood so wet my belt will slip, but never ahd an opi issue. When I bought mine to PO had capped all the vent lines and i iddnt notice til I did the cam, and I still never had an issue with it, even when the WP went out and the weep hole pissed all over it. I took the original ou at 108K since I was doing the cam and the only issue with it was the bearing wasnt as smooth as the new GM one I replaced it with.
#50
My 130k mile factory LT1 hit the red on the temp gauge, check gauges light on, multiple times. I then proceeded to spray a 150 shot on it, probably a good 10 to 15 bottles. That motor ran great until the day I yanked it to put my rebuilt/cammed motor in. Sure the LT1 has its problems, but these motors are strong and will take a beating.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
#51
first I didnt mean I work on my car every day some times I dont touch my car for weeks at a time...
#52
I plan on the Ls1 PCM conversion, but its not really due to the opti, it is due to the tuning. I rode in a pcm converted car, it ran so much nicer. It is only going to get harder down the line to find people who will tune a LT1 in person, I'm going to shoot for the route of the better PCM.
#53
#54
As it sits, it's TERRIBLE on gas
![Guns](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_guns.gif)
#56
That is another key reason that I'll eventually swap to the 24x kit. The drivability tune in our LT1 is marginal. It is tuned in open loop, and VERY rich @ part throttle to soften up the cam surge at cruising speeds.
I'm hoping that the LS1 pcm will help towards better drivability and efficiency.
