LPP Headers?
Old May 17, 2010 | 04:02 PM
Slow94Formula's Avatar
Default LPP Headers?
What kind of modifications have to be made to install these headers on a stock car? I read something about having to modify the K member. Is that only on an aftermarket K-member? What got changed in the new version of the headers? Will the oil cooler have to be deleted? How many of you have ever had a problem with the bolts breaking off in the heads?
Old May 17, 2010 | 04:07 PM
RamAir95TA's Avatar
I have a set of the original batch of LPPs and I had zero fitment issues. I think the issues you'll have are the same as any other long tube install.
Almost all long tubes require deletion of the oil cooler and the LPPs are no exception.
The factory used anti-seize on the manifold bolts, so it is unlikely that you will snap any manifold bolts.
Old May 17, 2010 | 07:35 PM
defaultexistence's Avatar
my llp clone version#1 longtube fitment issues when like this, #8 pipe needed flattened some because it was/is vibrating on the chassis ,the #1 pipe needed heated up and dinged where it was all over the steering link,the steering link also needed rounded and smoothed to add extra clearance courtesy of a bench top grinder.Had to notch the stock k-member on driverside to clearence the collector,my bmr k-member i have now has **** tons o' room. had to ditch the oil cooler,not that it made any difference.extended pass side o2. the angles @/with the y-pipe fit like **** and was binding on the headers. so i cut off the slip on joints bought turbo vband flange kits and welded them in ...imo that mod ROCKS! they don't leak and come apart easier when i need them to
P.S. do replace your motor mounts with poly ,it helps with clearence and makes engine rigid ,IMO
Old May 17, 2010 | 09:50 PM
What about spark plugs? Are any of them impossible to change with the headers on?
Also, What o2 extensions will I need? The car is a 94. How long? Flat or square connection? How many? etc.
Old May 17, 2010 | 10:52 PM
all plugs can be changed #2 pass side is a bitch but do-able #6 and #8 are best done thru the bottom after removing starter.dont let this worry you,also i found that running plug wires up to the plug as apposed to running them along the header flange like in stock location keeps them safe from touching hott headers.i also run my pass-side plug wires between block and acc bracket..."there is spot just above the idler pully to route them thru" then up to plugs..IMO this is way better than try'n to reroute them in stock placement. i cut and spliced in with two butt connectors a length off wire to reach pass-side o2's 700+ miles sofar on cardone select opti and msd vented cap, some house brand wires and longtubes.
Old May 17, 2010 | 11:28 PM
So... I will only need 1 extenson. Correct? I am just going to take the easy (granted, more expensive) route and get an extension. What size do I buy? 12 or 24 inch? Still want to know what the connection type is too. Thanks guys.
Old May 17, 2010 | 11:44 PM
12 will more than be enough, its the same connection as the o2 you have is ,look at it for reference if its a 94 then most likly one wire tube connector......................
Old May 18, 2010 | 08:52 AM
RamAir95TA's Avatar
The extension is a four wire 4 pin flat extension.
Old May 18, 2010 | 01:22 PM
wrd1972's Avatar
Sure would be nice if that great big *** LPP thread never got killed by the mods. There was so much good information in there.
Old May 18, 2010 | 04:58 PM
It must still be around somewhere...right? I never saw it, but if someone finds it paste the link in this thread please. I'd like to know as much as I can about these before I buy 'em.
Old May 18, 2010 | 06:05 PM
joe, why would the ext. wire be a four wire plug? if the o2 only has one wire...? or did they start using diff o2's as of 94?
Old May 18, 2010 | 06:51 PM
RamAir95TA's Avatar
93s are the bastard child - they do not have heated O2s. 94+ models have heated O2s.
Old May 18, 2010 | 07:34 PM
ok, i was thinking it didnt start untill 95. thx joe,..mike lol
Old May 18, 2010 | 08:30 PM
wrd1972's Avatar
That thread is ancient history. The mods killed it because LPP was the OP and they heavily marketed the headers. IIRC, once they ceased to be a paying sponsor, the thread was killed along withr all the valuable information. That thread had over 1400 replies and 70 or so pages IIRC.
Old May 18, 2010 | 10:26 PM
Meen95z's Avatar
My buddy just bought a set of the 1-3/4 to 1-7/8 stepped LPP longtubes in March and Id never buy a set. Id get the Edelbrock Stepped longtubes, kooks or hedmans. He ordered a set, look great, but the fitment sucked, they leaked, had to notch the kmember and had to use a jack to get the bolt holes to line up. I guess they had a Gen 1 set that sucked and a Gen 2 set that were good. Well my buddy paid for the Gen2 and they sent him the shitty Gen1's and he had all these problems and when he tried to contact LPP they refused to get back with him and finally emailed him saying he was **** out of luck. All he wanted was the right headers. Shitty customer service if you ask me. But thats just my 2 cents..
Old May 18, 2010 | 10:57 PM
sepno77's Avatar
I have the 1st batch and only mods I had to due was move the steering over a lil bit and delete my oil cooler.
Old May 19, 2010 | 05:43 AM
Chrismikeb's Avatar
when i bought my car it had lpp longtubes on it...fitment does suck (no idea if its gen 1 or 2 my previous owner is a dipshit) from day 1 the passenger side has leaked at the flange...he told me just need to change the gasket...come to find out he didnt have the last back bolt in, i couldnt get it in either...my uncle at his shop finally got it in but now its leaking from the center of the flange...driver side, he did some grinding on the steering knuckle..and i think the driver side header is sitting up against the frame...they look pretty but i wouldnt recommend them
Old May 19, 2010 | 08:35 PM
IMO...its always a good idea to check the header flanges with a strait edge for warpage or imperfections, if needed lay headder flange flat on a large belt sander to help correct/straiten surface so it mates with gasket/head properly .
<~Mike~>
Old May 19, 2010 | 08:47 PM
936spdZ28's Avatar
I have lpp longtubes on my 93. I had no problems at all. And all my wires are in the "stock" place.
Old May 19, 2010 | 09:12 PM
CONGRATS!
