burnt ingition fuse using LTCC??
Old May 17, 2010 | 06:49 PM
transmaro93's Avatar
Default burnt ingition fuse using LTCC??
hey guys my car is a pretty fresh build and yesturday was the first time i really gave it some real throttle and directly after i let off the car stalled out and wouldnt start. Well upon further investigation it was just a burnt 10A ignition fuse... my question is what might have caused this and could it be from the LTCC im using... its been running fine and was running fine after i replaced the fuse today, but i havent floored it again yet since so i dont know if it will blow again? Any thoughts?
Old May 17, 2010 | 07:09 PM
defaultexistence's Avatar
check all your wiring for a short that may have arc'd while engine/chassy was flexing
Old May 17, 2010 | 09:35 PM
jasonisdn's Avatar
they tell you to upgrade that fuse to a 15 or 20 amp
Old May 18, 2010 | 04:57 PM
really? any reason why it would boost more amps through there? is it just pulling more becuase its 8 coils instead of 1? i bought the kit used so i didn't know this. Your positive that you are supposed to put a larger fuse in there? because im not a fan of putting in larger fuses than is called for, but if they recommend it ill do it.
Old May 18, 2010 | 05:12 PM
jasonisdn's Avatar
yes they tell you to go with a 15 i believe. my owners manual is at the shop in car or i would take a photo of it for ya. trust me and step up to the 15.
Old May 18, 2010 | 05:40 PM
actually after i posted back.. i went and found the instructions online and it tells you to use a 20 in there.... so your right... thanks for the help i greatly appreciate...
Old May 18, 2010 | 05:42 PM
jasonisdn's Avatar
np man that's what we are all supposed to be here for.
Old Jun 11, 2010 | 12:48 PM
hilpala ss's Avatar
Good information to know. I too will be adding this Coil per Cylinder setup to my car within weeks.
