Progress was made today!
Old Jun 4, 2010 | 08:39 AM
  #61
Tapout911's Avatar
PM me if you wanna sell the EV hat. I hadnt planned on buying one yet, but Ill need one eventually.
Old Jun 4, 2010 | 09:09 AM
  #62
FASTFATBOY's Avatar
I was gonna send it back, BUT I will sell it to you less the credit card fee they were gonna charge me to return it, which was $20. You pay shipping.
Old Jun 4, 2010 | 01:44 PM
  #63
1936 LS1's Avatar
Looking good my friend! Not a quick fix but we could have a good f'glass shop section the middle part of the hood and raise it a couple of inches and glass it back together. Pie-cut it so only the rear is raised.
Just a thought.
Old Jun 6, 2010 | 11:43 AM
  #64
FASTFATBOY's Avatar
I started it last night for a few minutes with no radiator or front end on the engine. It wont idle, IAC is maxed out at 160...gotta figure that out.
I tell ya what it sounds CRISP when you pop the throttle.
Old Jun 6, 2010 | 12:01 PM
  #65
robsquikz28's Avatar
you ran it with no coolant in the engine? Wheres the vid of this bad ****?
Old Jun 6, 2010 | 12:05 PM
  #66
FASTFATBOY's Avatar
O yeh. cant run it long like that. No vid camera.
Here is an old video, sounds the same.
http://www.youtube.com/watch?v=1vNTWz4yvF8
Old Jun 6, 2010 | 12:33 PM
  #67
sounds the same huh, still sounds badass But I wanna hear the new setup lol
Old Jun 6, 2010 | 01:31 PM
  #68
Tapout911's Avatar
I always fire mine before putting all that crap on the front. Just long enough to check leaks, oil pressure, and see what the sensors are doing. Alot less to pull apart if something is wrong lol.
Old Jun 6, 2010 | 11:39 PM
  #69
94Z28rag's Avatar
towing it with a ford?
Old Jun 7, 2010 | 08:32 AM
  #70
Puck's Avatar
What, you gotta use em for something .
Old Jun 7, 2010 | 03:04 PM
  #71
FASTFATBOY's Avatar
That was a good ol truck, I sold it.
Old Jun 8, 2010 | 07:32 AM
  #72
FASTFATBOY's Avatar
Update.....I finished assembly last night, took that big Griffin radiator out and put a stocker in to see if it will keep it cool.
I got some bugs to work out....it HAD a check engine light out from the startup with no water pump(no coolant temp sensor for the ecm) It is now out but my fans come on with the key.
I deleted the temp sender in the head, I have a autometer gauge. My alternator is not charging...I am wondering if the ground path through the sender is stopping the alt from charging.....I have 0 volts on my energize wire to the alt. They are all innertwined in the gauge cluster.
My ram air hood and airbox are out, just plain aint gonna work. I have a buddy with a ASCD 2.5 inch cowl and he will swap me, not the hood I want but it will work. I am gonna do a through the core support intake tube with a filter behind the bumper.
Old Jun 8, 2010 | 07:57 AM
  #73
SLawson86's Avatar
the alternator actually gets power from the cluster. check for voltage at the alternator coming out of the cluster, the ground path for the temp sender/sensor shouldnt have a bearing on it. g/l, looks bitchin. i just bought a spectre hat myself... mine is a 4in raised ram air though, clearance isnt an issue.
Old Jun 8, 2010 | 09:08 AM
  #74
Puck's Avatar
Have you thought about a lid with under bumper ram air like the chris1313 setup? It's what I plan to be running, and seems to show real gains over pretty much any other setup.
Looks like you only have small annoying problems to work out, should have it good to go pretty soon!
Old Jun 8, 2010 | 05:06 PM
  #75
FASTFATBOY's Avatar
I will figure out the intake setup soon, I drove it today. Tune is off a bit you can tell but it drove good.
Old Jun 9, 2010 | 07:56 PM
  #76
FASTFATBOY's Avatar
The 95% finished product....Still gotta fit the cowl trim.
The entire intake setup will change, hood and airbox will be gone. gonna do a tube through the radiator support and a filter behind the bumper.
And oh yeh, touch up the tune.
Old Jun 9, 2010 | 09:05 PM
  #77
Speedy's Avatar
Sick. Really nice job. I'm using the Pro-tru pistons too, but they aren't dished like yours.
Old Jun 9, 2010 | 09:20 PM
  #78
BADHAWK51's Avatar
Looks like it's done with plenty of time to test out before the LTX Shootout.
I'm running my same setup this year then changing over to a similar setup to yours next year.
Old Jun 10, 2010 | 10:18 AM
  #79
Ed Wright's Avatar
9-Second Club
Open your throttle blades to lower the IAC counts.
Old Jun 10, 2010 | 12:34 PM
  #80
FASTFATBOY's Avatar
My IAC counts are normal now, I plugged the CTS up and its fine Mr Ed.
I need to figure out how to e mail you a Datalog so you can eyeball it.
