EGR Blockoff
Old May 27, 2010 | 09:13 PM
00FlowCamaro's Avatar
Default EGR Blockoff
I have all the blockoff plates on and tightened. I have a question concerning the block off plate on the longtube that would connect to the EGR tube. There is a gasket that came with my Pacesetter headers that I had on there and the bolt on the blockoff plate came loose and burned the gasket up pretty bad.
What I'm wondering is if I can run the blockoff plate on the longtube without a gasket and it will seal fine or if I will need a new gasket. Where could I find a gasket like that?
Old May 27, 2010 | 09:16 PM
RamAir95TA's Avatar
I would use a gasket on it. Exhaust leaks aren't fun, especially one before the O2 sensor.
Old May 27, 2010 | 09:17 PM
I suppose you wouldn't know where I could find such a small gasket? It came with the longtubes.
Old May 27, 2010 | 09:22 PM
RamAir95TA's Avatar
You can go to any parts store and buy a sheet of gasket material and make your own, or use RTV.
Old May 27, 2010 | 09:23 PM
What would you do, make your own or use RTV? Which would seal better in your opinion?
Old May 27, 2010 | 09:34 PM
RamAir95TA's Avatar
Since I have like 90 tubes of RTV in my toolbox, RTV.
Old May 28, 2010 | 06:12 AM
nighthawk15's Avatar
It almost definitely won't seal up right without a gasket of some kind. Some high temp RTV should work just fine.
Bahahaha, same here dude. Seems like I can never find one when I need it and end up getting another one to add to the collection.
Old May 28, 2010 | 11:25 AM
idformula's Avatar
copper ultra, I've used it as header gaskets before
Old May 28, 2010 | 11:39 AM
RamAir95TA's Avatar
That must be a freaking mess.
Old May 28, 2010 | 12:38 PM
idformula's Avatar
No, I didnt use it on a firebird or an LT, I used it on a free truck, and free rusty headers.
Old May 29, 2010 | 07:14 AM
Makes a little more sense but still sounds like a mess and a half.
