possible th350 swap?????
A good converter is going to cost you big $$, but well worth it as is a trans brake. I too got tired of breaking parts with the M6, and being horribly inconsistent.
Welcome to being a true player in the bracket race game
Get the Madman dipstick!
Weight-
4l80e- wet 255
4l60e- wet 175
TH400- wet 140
TH350- wet 130
Powerglide- wet 110
The Trans I posted has a 9" tail section. I got in contact with the original owner and was rebuilt 2 yrs ago, but only has 12 passes on it. Never gave the original owner any probs
So what size is the med tail shaft I need??
Weight-
4l80e- wet 255
4l60e- wet 175
TH400- wet 140
TH350- wet 130
Powerglide- wet 110
I have a 3" (tailshaft that is).
all i need really is a full list of evdrythign that i need.
if i go with a non lockup th 350 do i even need m6 harness. couldn't i just tape that away and not worry about any lights or codes coming on?
this woudl make it way easier for my but wouldnt i have to buy a different crossmember and torque arm mount braquet or qould i be able to use my stock trans member and just bolt the turbo 350 to it.
have you figured our with tail piece is the right length so you can use the stock drive shaft
i have a th350 that i am rebuildign myself right now. not as bad as i thought it woudl be rebuildign a old school trans
I've seen it back to back on a deadly consistent bracket car and it didn't slow down ANY
TH400 is def stronger, and heavier. When Im making 1000hp id consider it more. These trans are pretty cheap and everything can bolt right over if I decided to swap.
I don't have to ask them, I've seen it. For 95% of the race cars out there it will never make a difference and the 400 will hold up better.
yeah i heard it was a pita lol
