possible th350 swap?????
Old Jun 15, 2010 | 05:18 PM
  #41
AChotrod's Avatar
Oh I agree with you, but i also think the 350 has some advantages especially on lower HP cars like mine.
BTW I just bought the trans and it has a 9" TS but also bought a 6" TS and the correct output shaft for it.
Now I need a shifter, flex plate and converter. What suggestions do you all have on that??? What tooth flex plate do I need 153????? Any reviews on the B&M bandit stealth shifter???? Whats a great converter that is not 5million dollars???
Old Jun 15, 2010 | 05:23 PM
  #42
gregrob's Avatar
Sweet keep us posted.
Old Jun 15, 2010 | 06:30 PM
  #43
1badzee's Avatar
I recommended a converter earlier in the thread that won't break the bank. They also have a nice 8in converter for like 700 I believe.
Do you still use ABS? If not then that would be the easiest route to get a VSS signal. You just need to compensate for the front tire size and you need to put a different gear input in whatever you're using for tuning. It's pretty spot on with my car. Otherwise, let me know how that tailshaft swap goes.
Old Jun 15, 2010 | 06:36 PM
  #44
AChotrod's Avatar
No abs here!! Speedinc does my tuning and Ill double check the converter you suggested.
Old Jun 15, 2010 | 06:55 PM
  #45
1badzee's Avatar
Okay then you may want to consider routing the VSS wires to the ABS plug on the front driver side wheel. Took me like 20min for a nice clean routing. Much easier than changing out the tailshaft. But it sounds like you have to anyway for the proper length.. As for the converter, give them a call sometime and tell them what you want. They are very friendly and are as honest as they get with you. Excellent customer service.
Old Jun 15, 2010 | 07:38 PM
  #46
AChotrod's Avatar
Ill be changing the TS so I can just change the speedo gear if I need to.
Old Jun 15, 2010 | 08:08 PM
  #47
joelster's Avatar
Keep in mind that not only does the th350 weigh a shitload less than a 4L60, but if you get a GOOD 8" race converter, that weighs a shitload less than a 4L-lock-up converter. You get some of the flywheel effect, the motor will rev a little quicker.
Here;s a little picture of the fitz-all kit:
http://www.teckpak.com/spgm.cfm?id=V7-35B
It s a medium tail that you need for the th350.
Old Jun 15, 2010 | 09:19 PM
  #48
AChotrod's Avatar
Oh it will get a nasty good converter!!
I would have to buy a new cross member to use that fitz-all kit. Im a 6spd car and my cross member should work just fine with some shimming. I just wasnt sure which length to reuse my current DS. I did already order a med TS but dont think I will need it now. That spacer is prob about 3" so it eqauls the same length as the 9" TS on the trans.
About to order a B&m Bandit Pro Stealth Shifter
Only crappy thing is no t-brake but I still have a 2-step
Old Jun 15, 2010 | 09:28 PM
  #49
BADHAWK51's Avatar
Stepping up to Modified NA or PA Mike ? It's going to be a tough field this year. The Th350 is the way to go the only thing is you will have to rebuild it sooner than the 400.
Old Jun 15, 2010 | 09:29 PM
  #50
Big bird55's Avatar
Originally Posted by AChotrod
IS your car a auto now??
nope its a six speed right now, but the the trans isnt in it at the moment. i plan on putting the m6 back in it for like a year since my dad put some money out on parts for it but i will be gathering up the stuff for the th350 swap (if i get a good list with everything) on the side so when its time i can do it in one big shot.
Old Jun 15, 2010 | 09:32 PM
  #51
AChotrod's Avatar
I might run bracket or something
Yeah Im not worried about the rebuilds my car doesnt see much time out of the garage these days.
Old Jun 15, 2010 | 09:35 PM
  #52
AChotrod's Avatar
Well keep watching this thread and youll know everything youll need to for a m6 to th350 swap. BTW you can keep the M6 wiring and cross member!!
Old Jun 15, 2010 | 10:34 PM
  #53
Big bird55's Avatar
i already subscribed what all do i have to do with the wirign i am nto the best when it comes to wiring do i even need to have it to be street legal??
Old Jun 15, 2010 | 11:49 PM
  #54
1badzee's Avatar
Just tuck the harness away. Zip-ties are your friend. Mine is butted up against the frame rails, out of sight. Looks like I'll have some competition in 2011
Old Jun 16, 2010 | 12:00 AM
  #55
litch2004's Avatar
does this list of parts only apply to the m6 crowd? i have a 4l60 in my 93 and have had nothing but problems with it since the last rebuild. so i want to junk it for a 350 as well.
Old Jun 16, 2010 | 06:34 AM
  #56
suicidal racing's Avatar
So Are you guys sure the 6" is the correct length to keep the stock DS. I had always heard the long one is correct and now Im not sure.
you need the 9" tail shaft,its in the trans section on here.
Old Jun 16, 2010 | 06:48 AM
  #57
call ptc..they will set you up and not break the bank..i got a used hughs gm4500 off a buddy for 200$,the ptc would be around 400-500$
flex plate will depend on your converter..converters come in 10.75 an 11.50 bolt pattern.heres a dual bolt pattern one sfi approved.
http://www.summitracing.com/parts/QTI-RM-932/
shifter just get what ever one you like..pro stick,qautrer stick or cheetah..just make sure if its a reverse valve body trans you get a shifter for that.
you can build a th350 to take 650hp for around 300$ not counting core
Old Jun 16, 2010 | 09:28 AM
  #58
z28rob18's Avatar
yup^^^^ Wont work with a LS1 but will bolt right up to a LT1. Thinking about a swap now?? lol
lol yea ive been thinkin bout it for awhile i dont have money now but somewhere down the road im sure itll happen. if there were more heads up classes a six speed might work but everything is bracket racing
Old Jun 16, 2010 | 10:32 AM
  #59
AChotrod's Avatar
Thanks for the info. Trans is already built so Ill just have it looked over. It was behind a 9sec s10 so it should work great with my car.
Old Jun 16, 2010 | 11:47 AM
  #60
Big bird55's Avatar
and all my lights wll work so i can get inspected and be legal thanks
