List of stuff needed for installing headers
Old Jun 16, 2010 | 10:59 AM
nascarextreme's Avatar
Default List of stuff needed for installing headers
I have been doing some research and as far as I can tell this is all that I need, but I would like to make sure I have it all covered before I get started.
LPP headers
LPP y-pipe
Exhaust clamps
Poly motor mounts
Header gaskets
Header bolts
Valve cover gaskets
EGR block off plates
Flat O2 extension – (the car is a 94 so I should only need one… Right?)
Remove the oil cooler – (what exactly do I need to have to do this?)
New Spark plugs (tr55) and wires
Oil / oil filter
Also, how much HP should I be expecting to pick up with these specific headers? I had read somewhere that it is 30/30 hp/tq because of the special merge collector. Is that about right?
Thanks guys!
EDIT: an extra set of knuckles & patience
Old Jun 16, 2010 | 11:13 AM
Ruck's Avatar
you forgot an extra set of knuckles, a jack that can lift your car at least 4 feet in the air, and a case of beer.
Old Jun 16, 2010 | 11:19 AM
4u 2 nv's Avatar
add some patience to the list..
Old Jun 16, 2010 | 11:56 AM
Got that covered
Old Jun 16, 2010 | 05:06 PM
gregrob's Avatar
You need 2 block off plates. 1 for EGR and 1 for the pipe coming from the header.
Old Jun 16, 2010 | 05:58 PM
Pipe coming from the header? I thought LPP's didn't have any emissions stuff on them.
Old Jun 16, 2010 | 06:23 PM
gregrob's Avatar
Pipe coming from the stock manifold.
Old Jun 16, 2010 | 06:27 PM
So... with headers on I will only need one block off plate, correct?
Old Jun 16, 2010 | 06:28 PM
If I buy this will I be covered? >http://cgi.ebay.com/ebaymotors/93-97...Q5fAccessories
Edit: Never mind, I see now what you are talking about.
Old Jun 16, 2010 | 06:38 PM
GreenbeanZ28's Avatar
A BFH to bash those damned headers untill they fit.
Old Jun 16, 2010 | 06:40 PM
speed_demon24's Avatar
That so called merge collector is worth 0hp on a bolton car, probably worth 0hp on a h/c car too. Expect about 20rwhp max with a tune as well.
Old Jun 16, 2010 | 06:41 PM
Gotta love chinese quality. How are plug changes with the # 1 and 2 primary routing?
Old Jun 16, 2010 | 11:51 PM
Ruck's Avatar
i didnt use plates i just took egr out and welded ball bearings into the holes.
Old Jun 17, 2010 | 12:17 AM
Had to chop a plug socket in half to make a special socked for 3 cylinders, IIRC. Also had to drop the starter to get to one or two on the passenger side.
Old Jun 17, 2010 | 12:39 AM
Does anyone else know of anything else that I should add to the list, or have a write up on what has to be done to remove the oil cooler? I also want to confirm that I only need one o2 extension. Thanks guys.
Old Jun 17, 2010 | 04:44 AM
Jcl_96TA's Avatar
You may not have a oil cooler. It will have a adapter under the oil filter for the lines if you have one on your car. My car doesn't have one, but its a 96.
Old Jun 17, 2010 | 07:57 AM
1993 z28 f1's Avatar
Hey:
1 ea. 12" o2 ext for 94-97 pass side, is all I needed for my LPP headers.
Are these real LPP or the Chinese knock offs?
Real LPPs are made in USA not China as our fellow Floridian has told us many times.
Either way you still may need the BFH.
You'll have to disconnect the battery and remove the starter for the install, at least I did.
The oil dip stick was the biggest pain in my install as it was hard to remove and get reinserted after removal, it took some trial and error bending to get back in and sealed up.
Also I would add to the list some high heat reflective tape or wrap to put around the fuel lines or wires where they come near the exhausts.
Add two real sharp drill bits, and grinder to take some time off the poly motor mounts installation. drill sizes included in new poly mounts.
If you have an oil cooler you will need, to shorten or get two shorter bolts to fit the filter spin on inplace, I just shortened mine with the grinder. you also have to plug the lines @ the cooler/ radiator if you dont want a few oil drips on the headers.
You may or may not have to BFH the rear passenger side of the car near #8 and may have to slot (die grind/ drill) and move your steering linkage at the firewall towards the passengers side to allow proper articulation of the steering linkage and not make contact with the headers.
Be prepared for the worst and some long days and hopefully all goes well.
Good luck on your install and take your time, it never pays to hurry the 1st time....
Dub
When In Doubt Do Without
Old Jun 17, 2010 | 09:56 AM
^ wow, all in one shot! Thanks!
The ones I'm ordering are the real LPP's not the knock offs.
Old Jun 17, 2010 | 10:19 AM
I have not looked at mine to check, but it is listed in the RPO codes from Compnine.com when I put in my VIN, so I am assuming I have one.
Old Jun 17, 2010 | 10:21 AM
Barney Z's Avatar
Lots of time! Just got mine on and. . . . .Damn, it took foeva. . . .
