Ported Heads
Old Jan 15, 2004 | 12:46 PM
94Formula/TA's Avatar
Default Ported Heads
Anyone know where to get heads ported with good flow numbers for around $1500?
Old Jan 15, 2004 | 05:11 PM
lt4malibu's Avatar
where are you in south jersey?
Old Jan 16, 2004 | 12:39 AM
ten minutes outside of philly
Old Jan 16, 2004 | 07:12 PM
lt4malibu's Avatar
im guessing you have the aluminum LT1 heads, if you give me your email, ill send you some pics of mine. the machine shop doesnt have a flowbench(at least not that i know of, but they're workmanship is outstanding)
here is what they did for about $1500:
disassemble & measure
wash, glass bead, clean and inspect
port and polish intake & exhaust ports
polish & de-shroud combustion chambers
hone valve guides to true (.002-.0025)
grind 3 angle performance valve job
measure seat depth and equalize
mill .012 from head surface to flatten
dress edges & de-burr
grind valves & back cut face at multiple angles
match valve lenghts & grind tips
he also port matched my intake
Old Jan 16, 2004 | 09:12 PM
squinn's Avatar
I have started selling basically a CNC version of my head, as I run a gm casting lt1 head, I can give flow number if needed. $1495 with your castings, new valves, springs, ret, locks, ready to bolts on.
I started building my own web site, not done yet but you can take a look so far.
www.norushracing.com
Old Jan 17, 2004 | 05:18 PM
Uthinkso's Avatar
Check Your PM's
Old Jan 17, 2004 | 10:14 PM
BigEvil's Avatar
Originally Posted by Nick@AP-Engineering
Check Your PM's
Shoot me that one, too.
Old Jan 18, 2004 | 12:07 AM
Uthinkso's Avatar
Check your PM's BigEvil
