Engine Wash
A properly assembled/installed opti is NOT that prone to moisture problems. They do seem to be highly prone to being owned by idiots though.
but your also right. every distributor acts up when theirs moisture involved.
but to the OP you most likely killed your optispark...
I use a light bristle wire brush on any oxidized parts and a toothbrush with car wash soap on body parts, plastic parts, etc. Rag and none soapy toothbrush to clean up any soapy residue. Takes time but end result is near showroom condition.
If it's a 95-97 bullshit, unless the opti was on its way out already. I've sprayed mine many times with a pressure washer, hose, spilled on it from water pump installs etc and my OEM one was still going (even OEM cap&rotor at 113k).
1. Change opti
2.?????
3.PROFIT!
Then I saw the guy only had 2 posts. Guess he just got the car, decided to clean it up and learned one of the hardest lessons ever for the LT1.
