Ngk tr6 part #
Old 06-17-2010, 06:41 PM
RED PUNISHER Z's Avatar
Default Ngk tr6 part #
i need the part # ...i was told to buy these plugs if im going to run spray
Old 06-17-2010, 07:11 PM
stevo9389's Avatar
it is 4177
Old 06-17-2010, 08:37 PM
robsquikz28's Avatar
yes sir...4177
Old 06-17-2010, 08:39 PM
SexyTransAm's Avatar
dont run those plugs for spray. u need non projected plugs.
Old 06-17-2010, 08:41 PM
Ngk-3177
Old 06-17-2010, 09:15 PM
3rdgen92maro's Avatar
So what are the best plugs to run with N2O?
Old 06-17-2010, 09:18 PM
the 3177s aka BR6EF
Old 06-17-2010, 09:50 PM
Those are NGKs correct?
Old 06-17-2010, 09:51 PM
yes they r
Old 06-17-2010, 10:47 PM
the biggest shot im going is 100 and i will only spray like 2 times a month are thoes the best for me then or what
Old 06-17-2010, 10:48 PM
then the BR6EF will be great
Old 06-17-2010, 10:54 PM
ok thanks and i have them gaped at 35 right
Old 06-17-2010, 10:56 PM
thats what mine r at. 30-35 should be fine
Old 06-18-2010, 09:39 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
the BR6ef will work for a stock/bolt-on car plus a little spray...for a heads cam car I would run the BR6 as the NA plug and the BR7ef as the nitrous plug.
Old 06-18-2010, 09:52 AM
I thought you wanted the ngk number only for tr6....but yes as Ray said thats exactly what I would do.
Old 10-20-2010, 01:06 PM
JM0523's Avatar
So the BR6EF Stock No 3177 Will work on LS1?
Quick Reply: Ngk tr6 part #
