ARP head stud torq specs???
Old Jun 17, 2010 | 11:33 PM
Purple94Z28's Avatar
Default ARP head stud torq specs???
So i got some used arp head studs and im curious to what the torque spec is on them maybe even if there is a special order in which i should tighten them?
Thanks,
Nick
Old Jun 17, 2010 | 11:51 PM
robsquikz28's Avatar
65 with moly lube or 70 with engine oil
Old Jun 18, 2010 | 12:32 AM
jester1614's Avatar
and you tq them in the same order as stock headbolts. also dont forget to use sealer on the threads that go into the head
Old Jun 18, 2010 | 01:48 PM
Thanks guys!!
Old Jun 18, 2010 | 01:57 PM
draggin97s10's Avatar
he meant sealer on the threads into the block
Old Jun 19, 2010 | 12:04 PM
JAKEJR's Avatar
You're asking about the torque on the NUTS, not the STUDS, right? Two different specs.
Jake
Old Jun 19, 2010 | 02:49 PM
jester1614's Avatar
yeah thanks draggin.
and the studs are just hand tightened into the block
Old Jun 21, 2010 | 12:08 PM
are you sure about that. my buddy torques his studs then the nuts holding the heads on. i cant remeber the spec. but i beleive if they are hand tight they can come loose. Again this is just my opinion.
Old Jun 21, 2010 | 12:25 PM
SS RRR's Avatar
Village Troll
They will not come loose. As it has been stated the studs are hand tightened into the block.
Old Jun 21, 2010 | 12:29 PM
so my friend just does this for what reason. might i add hes been putting some fairly healthy motors together for 20 years.
Old Jun 21, 2010 | 12:35 PM
SS RRR's Avatar
Village Troll
I could give two ***** of the when/where/why/how of your friend or the reasoning. The fact of the matter is head studs only need to be hand tightened into the block. If you don't understand why then educate yourself instead of arguing your opinion.
RamAir95TA's Avatar
Head studs are always just hand-tightened into the block. Not every person who builds engines for 20 years knows everything.
Old Jun 21, 2010 | 01:37 PM
Didnt say that actually it was more of a question. personally i dont like studs so ive never used them. and im not claiming to know anything about them, but this is good information to know. and hahaa at you ss rrr your funny.
Old Sep 23, 2010 | 09:36 AM
DirtyBird310's Avatar
does it go the same 65ft lbs for the 13mm studs aswell cause i snapped mine last night
Old Sep 23, 2010 | 10:07 AM
quik95lt1's Avatar
just for some info on head studs or any stud for this matter.......the idea of a stud is to pull on the threads on the bottom of the stud...this is where the pressure gets distributed to.......they will not back off becuase of the pressure pulling up on them from the nut.......also another advantage is when they're being torqued the part in the block isn't spinning it simply being strethed........
the correct way is to put the stud in by hand.....when it stops turning you stop turning.....do not tighten them as much as you can by hand just stop when they stop.........use sealant on the end in the block and moly lube on the nut on the top.....also do not go straight to the 70ft/lbs......run three tightening sequences in the correct bolt pattern order 35lbs...55lbs....70lbs.....this will lay out the gasket nicely and give you a better chance at a good seal...........also THIS IS VERY IMPORTANT!!! !! if the studs are NEW install the heads and torque....start the motor and allow it to come up to temp then shut it off and let it completely cool then retorque the studs.....this only has to be done with brand new studs but make sure you do this....espically if you are running a metal layer gasket such as a cometic
hope this helps!!
Old Sep 23, 2010 | 10:17 AM
am_muscl's Avatar
so I hate to take a dump on this thread but what is the difference between the head STUDS and the NUTS?? because when I do my head swap I don't wanna f*ck it up.
Old Sep 23, 2010 | 10:37 AM
quik95lt1's Avatar
you mean head studs and bolts? not sure if i followed that....
