Anyone still runnings Delteqs???
I was reading about these when they first came out in production and over the years hearing bad brain boxes going bad issues. Along with the brain boxes going bad the company is no longer in business due to the owners health. So that being said replacement parts are extinct. The design was well thought out and did cure alot of ignition side of the optis bad design and longevity. I was just curious if anyone is still running them on this forum and how long they have had them and mileage spand so far. Im going to be building my motor shortly and trying to keep messing the opti limited as i dont want to pull it apart again to do one shortly after so i was looking at picking one up.
Thanks!
Thanks!
Im well aware a properly running opti is always the best route but the problem is there is always the bad batch of opti's that give it the bad name it has. Been down that road as many other can attest to owning an LT1. Problem is no one can trust an opti to last and im looking at possibly picking up an LTCC or Delteq if the price was right to help make things last longer. Mine lasted well over 205k and replaced it will a new GM unit and loctited the rotor screws and sealed it up still moisture got in and well thats all it takes. Its okay some people swear by running an opti so im not trying to start a never ending thread. Just want to drive my car not pulling it apart.
As for my setup i know you dont think its capable but thats why its my car and not yours to worry about. I plan on rebuilding the bottom for high compression so i can run the 64cc heads and have a motor capable of making good bottom end power. Thanks for replying again.
I'm running one and ZERO issues for over 4 years. True, I only drive my car 4-500 miles a year at most, but I love it. Dread the day the brain goes dead, but I'm planning on it happening eventually.
If you wanna spend the cash go with the LS1 computer conversion as it has wayyyy more tunability and lots of guys love it. There is also LTCC, as well, but you still have to rely on the CPS from the opti as with the Delteq setup.
I know some people say the opti isn’t as bad as it seems but I’ve had three optis over the past 2 ½ years, with less than 8k miles on the car. I installed the first one myself but it turned out to be a “fake” eBay opti, which was DOA after 300 miles. I had that one replaced with an AC/Delco opti, installed by a mechanic, which ended up being DOA after about 5k miles when a car wash attendant blasted it with a pressure washer. I had that one again replaced by a mechanic and it’s running fine except for a recent incident where it was raining hard and I got the dreaded stumble and SES. I just let it dry out and it’s running fine, but I won’t take a long trip in my car if there is any chance of a heavy rain.
Point is, unfortunately it seems like it’s a “hit and miss” thing with optis. A stock part shouldn’t have to be modified for it to work correctly and they seem to go whether a pro or a shade tree mechanic installs it. I read a lot of LT-1 related forums and the opti by far is the number one complaint about the motor. It’s too bad no one has come up with an inexpensive “true” opti replacement.
Haha
I have not touched my opti in over 3 years and 60k miles. Miami likes to flood alot. Ive had water over my hood numerous times from misjudged puddles. Car has never once batted an eye. Do it right with quality parts, time and cleanliness.
If you really want to abandon the opti, yank the engine and go with a distributor or install a MSD ignition system with a crank trigger. Anyway you look at it, a properly installed/maintained Opti is going to be cheaper.
Long Live The OptiSpark!
EDIT: Ill sell you one guaranteed to last, long as you don't hit it with 4500 psi of water.
Haha
http://www.eficonnection.com/eficonnection/default.aspx
Also, here is a thread of a guy doing one now:
https://ls1tech.com/forums/lt1-lt4-m...ions-****.html
