Seal question
Old Jun 29, 2010 | 09:06 AM
97 SS LT1's Avatar
Default Seal question
There is a seal on the timming cover for the water pump shaft....i have replaced it 6 times and it still leaks!!! I have tried several different way to put it on, but it either rips or goes for a while (a few miles) then starts leaking again! any ideas on how to put it on so it doesn't strech or rip??
Old Jun 29, 2010 | 09:31 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
If you search, there are numerous threads.
Old Jun 29, 2010 | 09:56 AM
97 SS LT1's Avatar
i used the search button...maybe i'm not putting in the right words?
Old Jun 29, 2010 | 10:06 AM
ulakovic22's Avatar
Electric tape the gear and get a socket to put it on. 6 times and it still leaks.....must be doing something wrong. It's a seal you drive into place. Is it leaking out the shaft or from around the seal/timing cover?
Old Jun 29, 2010 | 10:18 AM
97 SS LT1's Avatar
it is leaking around the shaft and the seal. granted a few of those riped going on. i have had 3 that have leaked on the car. the ID is alot smaller than the OD on the shaft and everytime i put the seal on it rips or streches out to the point that it wont seal.
Old Jun 29, 2010 | 10:23 AM
BTC's Avatar
BTC
I used a deep well socket. I think I warmed the seal up with a hair dryer and boiling water to get it onto the socket, placed the socket over the shaft, slid the seal onto the shaft and then drove it into place. A lot of people use a sharpie pen.
Old Jun 29, 2010 | 10:41 AM
97 SS LT1's Avatar
i haven't tried to warm the seal up yet...i will try that next! thanks for the ideas!!
Old Jun 29, 2010 | 11:41 AM
shbox's Avatar
http://www.impalasuperstore.com/nais...TOPIC_ID=30984
Old Jun 29, 2010 | 12:09 PM
BTC's Avatar
BTC
That's a nice, entertaining thread. That opti seal is huge in comparison to what's on my '94.
I also oiled up the deep well socket I used during installation. I've heard that seal is supposed to go on dry. I don't know whether that's true, but mine didn't leak.
Old Jun 29, 2010 | 01:37 PM
97 SS LT1's Avatar
once again you have came through!! Thanks for your site and this!! wish i would have had this the first go around!
Old Jun 29, 2010 | 05:00 PM
buffman's Avatar
I sell the proper tool needed for installation of the water pump seal. Unlike a socket it's tapered so you can easily install the seal (yes install dry)
Old Jun 29, 2010 | 07:40 PM
old93camaro's Avatar
buffman how much for the tool send me a pm i need on asap
Old Jun 29, 2010 | 09:28 PM
buffman's Avatar
Sent PM
Old Jun 29, 2010 | 09:40 PM
spudnick3119's Avatar
I just kept on stretching the seal a little bit at a time with increasing diameter sockets. Once its stretched enough, I used the water pump coupler (cleaned it up with steel wool first), slid the seal on that and then slid the coupler/seal in place and tapped the seal on. I used a bit of oil and I haven't noticed any leaking.
Old Jun 29, 2010 | 11:38 PM
buffman's Avatar
Yeah, but proper tools make it so much faster and easier
Old Jun 29, 2010 | 11:55 PM
shbox's Avatar
A deep well socket worked fine for me.
Old Jun 30, 2010 | 05:17 PM
leadfoot4's Avatar
Yes they do!!!
I bought one of these tools earlier this year. Worked like a charm!
