Quick Question!
Old Jun 29, 2010 | 12:42 PM
red-_-z28's Avatar
Default Quick Question!
Have having no lash how much do you guys turn the nut?
I have heard 1/4-1/2 from Kim Barr Racing!
1/2 from a couple of other guys
3/4 from my chilton book
1 from ALLDATAdiy.com
So what is it? haha thanks guys!
Old Jun 29, 2010 | 01:43 PM
fleetmgr's Avatar
1/2 turn. I do them with the engine running. Loosen until it starts to tick, then tighten until is stops ticking, then another 1/2 turn.
Old Jun 29, 2010 | 03:41 PM
red-_-z28's Avatar
Well the engine isn't able to run. But I've always done 1/2 but I keep hearing diff. things soo can I get a couple more responses. 1 reply with 40 views come on guys I need this kinda quick.
Old Jun 29, 2010 | 03:42 PM
draggin97s10's Avatar
1/4 1/2 3/4 1 ive done all never had a problem. id say as little as possible.
Old Jun 29, 2010 | 03:49 PM
defaultexistence's Avatar
1/2 turn when you feel good drag on pushrod with fingers FTW!
Old Jun 29, 2010 | 03:51 PM
red-_-z28's Avatar
Haha that doesn't help much. We did it to 3/4 and we decided to take some off so were at 5/8. Should I leave there? All the help will be appreciated!
Old Jun 29, 2010 | 03:56 PM
red-_-z28's Avatar
Hahaha do you think I'm good where it's at now?
How serious is this on how the engine runs depending on how much you tighten it?
Old Jun 29, 2010 | 03:58 PM
its really not that complicated..... go to shbox.com and do what is discribed
Old Jun 29, 2010 | 07:02 PM
red-_-z28's Avatar
Who said it's complicated? I've just heard many different things so I come to you guys to see what y'all doo...
Old Jun 29, 2010 | 07:51 PM
goto www.shbox.com !!!! will help you with anything to do with this car
Old Jun 29, 2010 | 08:02 PM
gregrob's Avatar
Depends on the lifters... stock I go 3/4-1 full turn. That is factory spec..
Ideally you want .060-.080 preload.
Old Jun 29, 2010 | 08:14 PM
fupa's Avatar
If the engine doesnt run, the lifters are probably gonna be bled down. Might be a good idea to either get the lifters sitting in a bucket of oil, or prime the engine prior to setting the lash.
Also Ive heard that once you set the lash, dont back off or make any other adjustments. The second you set them, the pressure of the pushrod against the lifter is gonna bled the oil out and the idea is to set the lash with the oil in the lifters. Anyone else please chime in on this, Im not an expert but just sharing some info Ive heard threw the years.
Old Jun 29, 2010 | 08:55 PM
96capricemgr's Avatar
"spin the pushrod" will nearly always be WAY too tight. Soaking lifters in oil is pointless.
I have never bothered with running adjustment. Do a cold static adjustment is fine if you know what you are doing.
Biggest mistake is usually screwing up "zero lash", zero lash is when the pushrod no longer moves up and down between the lifter and rocker. With polylocks this is when the nut hits the trunnion of the rocker.
Different lash setting may be for DIFFERENT PURPOSES, most of us here have something different in mind than what GM intended so their spec of one turn might be fine for a bone stock car but might not be right with a cam turning 1000rpms higher with twice the pressure over the nose. Half a turn is pretty safe and decent no matter the use.
Old Jun 29, 2010 | 08:57 PM
Jon@BruteSpeed's Avatar
LS1TECH Sponsor
How high do you spin the engine? When I started to spin my stock engine to 6600 just to get it through the traps, I backed them off to 1/2 turn pre-load. You can typically get a couple hundred more rpm out of a motor with less pre-load. If you not are not spinning it high, 1/2 to 1 turn will be fine.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Old Jun 29, 2010 | 11:05 PM
red-_-z28's Avatar
i know of the website, trust me.
Old Jun 29, 2010 | 11:09 PM
red-_-z28's Avatar
alright thanks guys!
the car's almost ready for start upp!
