dropped a pushrod ??
Old Jul 11, 2010 | 09:03 PM
RED PUNISHER Z's Avatar
Default dropped a pushrod ??
i just got this car 2weeks ago its a 93 z28 355 lt4 cam comp springs 1.6 rockers ported heads and intake and full bolt ons motor only has 400miles on it and i have all the receipts so everything it legit ...the guy told me the only thing i needed was new lifters ..the motor was ticking like it needed the rockers readjusted or it needed new lifters ..so today i was going to readjust the rockers and see if the ticking went away so i pulled off the valve covers and on the driver side 4th rocker form the fire wall the bolt that holds the rocker down was broken with some of the tip or the rod in it so the rocker was just loose and the 3rd rocker form the fire wall the push rod was missing??? .... i was driving the car like this for 30 miles it felt like it had a miss at idle but it ran smooth when i would cruise it ...is it possible that the rod fell in the motor if so how do i get it out and where will it go if it did and whats the name or the rod that you bolt the rocker to...please help
Old Jul 11, 2010 | 09:06 PM
zbomb5610's Avatar
the guide plate stud is what the rocker is bolted down on, that is weird that the pushrod is missing. maybe it snapped and it is sitting in the lifter valley. not really sure.
get some answers from other people but you might need to pull off the intake manifold to get a good look down there.
Old Jul 11, 2010 | 09:10 PM
RamAir95TA's Avatar
Before you do anything I'd start pulling it apart.
Old Jul 11, 2010 | 09:22 PM
hear is a pic the bolt im holding is what broke with the stud in it
Old Jul 11, 2010 | 09:24 PM
i guess ill pull the intake off and start looking
Old Jul 11, 2010 | 09:29 PM
Old Jul 11, 2010 | 10:30 PM
anybody else have any info ???
Old Jul 11, 2010 | 11:03 PM
found it ...it was in the lifter valley
Old Jul 11, 2010 | 11:05 PM
dan catalyst's Avatar
fish around in the pushrod hole with a magnetic tool picker upper thingy(lol) and you might be able to get it out without pulling the intake.it is in there laying in the lifter valley,prob all bent up.id just replace that one rocker stud and then do a leak down test or at least a compression test on that cyl.
Old Jul 11, 2010 | 11:06 PM
oops, haha.you posted while i was responding.
Old Jul 11, 2010 | 11:15 PM
where can i get new stud for the one that broke and what rods do i go with since i have every thing open ill new new ones ans get some ls7 lifters
SPEED#1's Avatar
OK, order up 1 new pushrod from summit. Secondly that roller rocker poly lock is not broke that your holding. Its still good and the other ones in that pic are all loose. Find out how to adjust them correctly and I say you will be good. I think the person never adjusted them correctly and they were just loose. But order 1 new pushrod.
Old Jul 11, 2010 | 11:16 PM
SPEED#1's Avatar
There might be a pat number on the pushrod. Order that one unless you will have to measure it and check it.
Old Jul 11, 2010 | 11:20 PM
BlackBird87's Avatar
Order a whole set of hardened pushrods
Old Jul 11, 2010 | 11:23 PM
are these good
http://cgi.ebay.com/ebaymotors/ws/eB...d=270545379316
Old Jul 11, 2010 | 11:25 PM
Yes, i was going to order the same ones when i did pushrods
Old Jul 11, 2010 | 11:33 PM
hyperzone's Avatar
Check with Thunder Racing for the pushrods. I was going for a set of comp hardened rods but, ended up getting a set of their brand for a bit less. They looked identical to the comp ones.
Old Jul 11, 2010 | 11:35 PM
Ok good
Old Jul 11, 2010 | 11:37 PM
$119 from their site.
Old Jul 11, 2010 | 11:42 PM
RamAir95TA's Avatar
Just buy a set of Comp hardened. They're like $40.
