CC503 LT1 Dyno graphs
Vegas isn't 4000 feet above sea level but with the conditions it will make cars run like they are 4000 feet above sea level. I always heard you lose 3% power for every 1000 feet above sea level you are which could mean atleast 30hp right there just due to elevation.
Running drag tires and having an auto also lower the trap speeds some compared to an m6 but that doesn't mean your m6 would win a race against a similarly equipped A4 car
One night i spun very bad but decided to salvage the run my slip looked like this:
60'--------2.5(continental 275-40-17
)1/4-------14.5
mph------104.5
bolted the DRs on (bfgs
)3000' DA60'-------2.0 hooked hard then clutch slipped
1/4------13.35
mph------105.2 exploded clutch
OP do yourself a favor get a stall or your car will be a PIG out the hole! Unless you have N2O
...... well look let me tell you a story im still stock just straight piped with a stall and i had bad tires and beat another auto t/a lt1 with lt headers and all the shubang except a stall andi smoked him by 3-4 car so i suggest you get a stall thatll be good for your set up
trust me when your an auto its a must
OP
don't listen to this guy ask questions here,many of us have had or been through these cars and know what they like and the compromise of being able to go fast and not be a PITA to drive around......i suggest you meet up with someone by you that has a stalled car and go for a ride, they may even let you drive it to see how a car with a REAL CONVERTER drives like
