Did my clutch die?
Did my clutch die?
Hi guys, I recently picked up a 97 Z28 M6, 102K miles, bone stock except for a Flowmaster catback.
Recently I believed my clutch died. I was in third going about 40-50, ready to hit fourth, but when I put my foot on the clutch it would grind and shake violently not allowing me to go into gear or slow down. I put the car into neutral and coasted into a parking lot and then the car died with the clutch in. Now it won't crank at all.
Before this happened I had some issues with the shifter staying in 3rd gear, if I firmly place it there then it will stick but if I just gently put it there it will pop back out into neutral. Also, 5th gear is hard to find under load or parked, I would have to go into the previous gear and try several times.
Is it the clutch? What can I do to start trouble-shooting this? Is there a cheap replacement? I just want the car running smoothly again, not really looking for any performance right now.
Any advice is greatly appreciated.
agreed. pull everything apart first. if you need a clutch tho. i really like my spec stage 2. but it chatters alot. Monster clutches ive heard nothing but great things about. the next time i need a new clutch ill be purchasing a monster
Could be the clutch fork bolt. The fork could be making the noise your describing on the pressure plate. Take off slave with metal portion and peek in access hole. If fork is completely loose, it is bolt or throwout bearing.
You can see more with a flashlight and mirror, and go from there.
Well I dropped the car off at a shop to drop the transmission and take a look.
They said the clutch is indeed gone so a new replacement is needed. They also mentioned my third gear is damaged and needs to be replaced, however, I have no idea what kind of part is needed for this. Whats needed to replace a gear? I checked at Autozone and it was about 300 ish for a stock replacement.
Is it normally this much to replace a gear? Any advice is greatly appreciated. I just want the car running correctly, not looking for any performance parts.
What do you guys think?
