lt1 motor woes
Old Aug 10, 2010 | 11:55 PM
speedracer2536's Avatar
Default lt1 motor woes
well im putting my shortblock together and i have run into two issues.. one.. i had to get another piston due to one being cracked.. well it came with a rod as well.. i went to install it and the big end is to wide to properly fit onto the crank shaft.. when i torque'd it down the crank wont spin over.. can i have this rod machined to be thinner or do i need to put the new piston back on my old rod? the rods came from another lt1.. i thought they were all interchangable..anyone have any input on this??
second.. i have a set of 1.6 harland sharp rocker arms that scrape the bottom on the rocker arms on stud.. is there any way to remedy this? should i modify the rocker to clear? it is just takinng the paint of the rocker but i dont like that it hits... do they make a stud with a little fatter base on it? this is the kit that i have now.. and these are the rockers
http://www.jegs.com/...4-7104/10002/-1 studs
http://www.jegs.com/...1/1002/10002/-1 rocker arms
Old Aug 10, 2010 | 11:56 PM
and just to clear it up.. i have seven rods and pistons from the original motor.. one piston and rod from another motor..
Old Aug 11, 2010 | 12:09 AM
fleetmgr's Avatar
Have the new piston installed on your old rod.
Old Aug 11, 2010 | 12:36 AM
i think i found my mistake..i actually mixed more pistons and rods than i thought and wound up with 3 rods that have the pistons on backwards.. so i have two that have the chamfered sides facing each other.. would that cause the clearance to be too tight?
Old Aug 11, 2010 | 12:43 AM
brucer's Avatar
yep
the chamfers go towards the radii on the rod journal..
you need to pull the rods and pistons back out and check them.. make sure you didnt bend the rods if you torqued the rodbolts..
Old Aug 11, 2010 | 01:06 PM
how would the rods bend?
Old Aug 11, 2010 | 02:22 PM
lt1-xjs's Avatar
I would suggest a competent shop build the motor.
Old Aug 11, 2010 | 04:23 PM
it was an honest mistake.. i just wasnt paying attention.. i have built motors before..
