AI 355 Build Thread and More
Old Sep 19, 2010 | 04:05 PM
  #81
SpeedDensityZ's Avatar
Originally Posted by _twisted_
Thanks for sharing all this info, f- bodies are new to me - so all the pics and info of what worked and what didn't will make my project easier to tackle.
I have a 94 Formula, all stock w. slp cold air and a loudmouth, 110,000 on the clock, and at least 60k on the opti, if the original owner didnt replace it then it has 110
Good luck with your build. You'l hate to love it!
Old Sep 19, 2010 | 08:41 PM
  #82
grn95t/a's Avatar
damn, wish i could find a sweet deal on a rear like that! killer man!
Old Sep 19, 2010 | 09:09 PM
  #83
1961ba427's Avatar
Originally Posted by SpeedDensityZ
I just got back from Tampa with a Moser 12bolt. It has 33 spline axles, 3.73 gears, and an eaton posi. I plan on replacing the posi with a spool since the spider gears are pretty much trashed. The ring gear looks to be in excellent shape though, it only has a couple small chips in it and they are not located in the wear pattern. I got it for 900.00 which I think is a pretty good deal. I should have it done and finished for under 1150.00.
I was watching that since it popped up a couple days ago....was hoping it would end up in a silver lt1 camaro...just mine instead of yours. lol I had just spent my money on some other parts instead. Do you know if anyone sells a housing and axle package for the 12 bolt? I have asked in the gears section and all I get for replies are to use a 9"....9" costs about the same......blah blah blah.
I don't have anything against the Ford rear, but I prefer the 12 bolt....plus I already use 12 bolts in other stuff, and have a spare posi, spare spool, spare gears, etc.
I just need a torque arm compatible housing.
Old Sep 19, 2010 | 09:53 PM
  #84
Thanks, it seems I can never find one for sale period and when I do they want an arm and a leg. Me and my dad have set up a couple and they were fine, so were going to do this one too. I knew I was going to have to find a fixer upper.
I don't think anyone sells an axle/housing combo for the 12 bolt. I know the 9in. housing and axle combo usually runs around 1000.00 but, id doesn't come with a center section. That's the expensive part. You'll tie over 1200.00 up in it using mediocre parts. Yeah, I had been saving for one and when the ad popped up I called and got lucky.
Old Oct 1, 2010 | 06:25 AM
  #85
Well, since I'm low on cash at the moment I did some piddling around and finally painted the intake and radiator support. I also mounted the fogger nozzle in the intake tube. I am buying my spool next week and will have pics of the rearend done and installed. Here's some pics of the intake. It was painted the same color as the car.
This is where I mounted the N20 solenoids on the frame rail where the ABS once was. I'm wiring it in today and doing a wire tuck on the passenger fender.
Old Oct 1, 2010 | 08:25 AM
  #86
ScreaminRedZ's Avatar
registered user
Very nice job with the build. I can't wait to see how it dynoes and runs at the track. Good luck!
Old Oct 1, 2010 | 07:43 PM
  #87
Thanks, shouldn't bee too much longer and I'll have it at the track. I'm using track money for mod money at the moment. Anyway, I finally did the wire tuck today and it turned out really good. I just need to clean the engine bay up and get ready for a car show next weekend. The next thing I plan on doing is an alternator relocate. I'm going to modify the stock bracket so we'll see how it turns out. I just drilled a hole on the back of the shock tower near the CPU and run the wires underneath the inner fender well and hooked to ground up in the same location. Took about an hour, could have took less time if I had all the right tools. Here are some pics of the wire relocate.
Before:
After:
Old Oct 1, 2010 | 08:46 PM
  #88
flyinZ's Avatar
Damn, I've got to do that wire mod, lol. Looks good man!
Old Oct 1, 2010 | 11:23 PM
  #89
Thanks, it really cleaned it up. I did the fuel lines and was so happy with it I did the passenger side too.
Old Oct 2, 2010 | 12:04 AM
  #90
ThorsLT1's Avatar
where did you reroute them? in the fender? is there a write up?
Old Oct 2, 2010 | 06:30 AM
  #91
MattSapp95_T/A's Avatar
Yea through the fender... Drill a hole right above the PCM and run the wires through it... Really easy... There are some write ups if your search for "wire mod"
Matt
Old Oct 2, 2010 | 06:42 AM
  #92
Here ya go, it is for an LS1 car but, you get the idea.
https://ls1tech.com/forums/appearanc...al-inside.html
Old Oct 2, 2010 | 08:56 AM
  #93
registered user
Nice job with the wires. I'm interested to see how the alternator relocation goes, there are definitely some cool home-built setups out there.
Old Oct 2, 2010 | 09:43 AM
  #94
It will turn out great we are going to do it just like i did mine pictured on page 3....
Yea I like DIY stuff gives you more of a since of pride
Old Oct 2, 2010 | 02:22 PM
  #95
Well, I finished wiring in the nitrous today. It went nice and smooth without any hiccups. I decided to crank the car up and wouldn't you know it the FN ignition switch quit working. It has on but it doesn't have run and start. I knew it was coming, it had been giving me some problems. I suppose the contacts are wore out. So, now I have to drop the steering column and replace it, has anyone ever done this and give me some tips on how to make it easier?
Old Oct 2, 2010 | 03:46 PM
  #96
Yea sale that turd and buy a honda!
Old Oct 3, 2010 | 01:13 AM
  #97
96ssindeed's Avatar
Lol. This would be funny if i hadn't just sold mine to start driving my old civic again.
Old Oct 3, 2010 | 02:41 AM
  #98
Rob94hawk's Avatar
After:
Nice! How big was the hole you drilled and did you use a grommet. I'm gonna do this on monday.
Old Oct 3, 2010 | 09:34 AM
  #99
All I had was a 1 inch drill bit. I drilled two holes and ground the center out. So it was actually an oval hole. Just the right size for the conncector. I didn't have a grommet that big so I used a piece of hose cut down the center.
Old Oct 8, 2010 | 12:02 PM
  #100
I cleaned the engine bay up yesterday and I just couldn't believe how far it has come in just a few short months. Here is before and after pix of the engine bay. Not a great close up but, it's all I can find.
Before
After
